Results 1 to 7 of 7
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Headlight 'big' condensation issue/fix :)
    For what it is worth....
    So i have a S6 C7 2013 (second hand), only to discover during heavy rain one headlight had BIG condensation issues. I know you can have a little bit but that quickly vaporise after few mintues driving (the headlight has a fan inside).
    On first look the headlight didn't had damage from previous owner, i tried to seal the gap where the glass meets the plastic housing, but that didn't fixed it.
    Before going to stealer or remove the entire headlight myself, i removed the airfilter box and had a closer look.
    Nothing odd....untill i decided to remove the cover.
    Apperently someone broke all 4 taps (holding a printboard) witch made it possible for water/vape to enter the light!
    Not sure how it happend, but even the cover corners aswell where in poor condition (cracks).
    In short, was able to order a new cover at the dealer (+-20€) and no condensation issues anymore :).
    Picture of the old cover after a quick tempuary fix
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Oct 22 2014
    Atlanta, GA
    Quote Originally Posted by Dasquade View Post
    Bravo! Always worth to have a look first. Glad you were able to take care of it yourself
    Sep 07 2010
    Belgium
    Reviving my old topic as it might help others...
    So after i had condensation on my right headlight, last winter and now that rain is coming again here, i started to have the same 'big' amount of condensation on my left headlight. I knew i had a little crack on the top but had sealed that last winter. But last week i had the issue again and decided to finally try remove the secundairy airfilter and have a look at the headlight cover witch was the cause on the right headlight.
    And yeah, as hoped, 3 of the 4 tabs holding the printboard where broken of and left 3 holes in the cover. Also at least 1 corner was cracked...
    Looks this isn't a coincidence and somehow 'wear and tear' and prone to fail (i suppose heat and vibrations make them break?).
    Anyway, got a new cover from the dealer 4g0 941 159 at 9,60€. Hope the water viporise now and soon a dry headlight again (the right one stayed perfect dry since i replaced). As always, more frustration removing and putting back in (hard to access bolts as always).20190929_134945.jpg20190929_134905.jpg
    Mar 11 2007
    4L Q7 3.0T Stage II, D4 A8L 4.2, A5 2.0t APR stage III, MK1 TT 225 APR stage I
    Colorado Springs
    Good play.
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Feb 03 2016
    Cleveland
    My personal experience: was procrastinating getting headlight fixed after someone bumped it in a parking lot and cracked the lens, headlight ended up burning out and shorting the leveling motor. Was about $3000 if I remember correctly. Moral of the story, get it fixed before it ends up costing a bunch of money.
    Mar 05 2012
    Sidney, ME
    Going to call dealer today!
    Sep 07 2010
    Belgium
    Quote Originally Posted by pottle View Post
    Glad you easly found the topic.
    In case it are the covers, try to keep them open in the garage and get some air in them.
    I needed the car and had to put things back...took at least 2 weeks before all condensation finally made its way out of the unit, but since then both dry again.
