Results 1 to 27 of 27
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Cluster removal instructions: Anyone?
    Looking for directions on how to remove the dash cluster (speedo). I found B6 directions etc, but I am a technical idiot and need to see everything in pictures or video. :) If anyone could help, it would be appreciated.
    Also, if I replace my broken dash what is needed and how hard is it to program the new dash?
    Apr 05 2016
    Portland, OR
    It is pretty easy, similar to other cars.
    I don't believe anything is stored on the cluster itself so you should just be able to swap them.
    Lower the steering wheel all the way.
    Remove the trim. (It just pops off, drivers vent will also come off. On B8.5 you will need to either unclip it or remove the plug on the back)
    Undo the 3 screws (See pic)
    Undo the latch on the back
    Here is the pinout:
    Code:
    1 - 	Not used
    2 - 	CAN bus (screening) wake-up wire
    3 - 	CAN bus (Low) wake-up wire
    4 - 	CAN bus (High) wake-up wire
    5 - 	Sender earth for fuel gauge sender -G- - pin 2
    6 - 	Fuel gauge sender -G- - pin 4
    7 - 	Fuel gauge sender -G- - pin 3
    8 - 	Switch panel
    9 - 	Fuel gauge sender 2 -G169- - Pin 2
    10 - 	Fuel gauge sender 2 -G169- - Pin 1
    11 - 	Not used
    12 - 	Not used
    13 - 	Not used
    14 - 	Not used
    15 - 	Not used
    16 - 	Not used
    17 - 	Not used
    18 - 	Not used
    19 - 	Not used
    20 - 	Check button
    21 - 	Not used
    22 - 	Not used
    23 - 	Radio-controlled clock 5V
    24 - 	Radio-controlled clock signal
    25 - 	Oil level
    26 - 	Not used
    27 - 	Not used
    28 - 	Not used
    29 - 	Terminal 31
    30 - 	Terminal 31
    31 - 	Terminal 30
    32 - 	Terminal 30
    Geoff
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ă C, CĂ*
    There is component protection on it and the cluster keeps the mileage on it, so swapping is not direct.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by infinkc View Post
    Damn. Just like my old car
    Didn't see anything on that in the notes so figured it was stored in the ECU.
    Geoff
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Still great info.. so how exactly do I move the info over? Find someone with a Vag?
    Ignorant to this... so excuse me!
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Also...
    I looked at my cluster briefly yesterday so ill have to look again, but do the "square buttons" pop off? or do they come out with the cluster? Does anyone happen to have a video of the b8 removal?
    I just want to be thorough, screw for screw, etc...
    Apr 05 2016
    Portland, OR
    B8 or B8.5?
    Square buttons in the instrument cluster probably come off with the cluster.
    Hazard light switch on the B8.5 comes off with the trim piece.
    Geoff
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    ok..
    http://www.audizine.com/gallery/data...m/cluster4.JPG
    I think you maybe right... Now if I could find a video or instructions that are the "same dash" being removed. I am not technically savy when it comes to taking things apart and need to know every bolt, etc...
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    I need to remove mine to figure out how I am gonna correct all of the fine scratches that I have on the plastic. Anyone advice or technique to get in there would be appreciated. I know a rupes ibrid nano would do wonders.
    The Audi Alpine aftermarket head unit video has a demonstration of it, as they put the GPS antenna behind the cluster. Here you go.
    https://www.youtube.com/watch?v=DwiPIYcLQ9Q
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Would the new/replaced cluster show the mileage from the previous car? Could the new cluster be programed to the mileage of the OP's car? I know some clusters need to be programmed on a dealer computer otherwise they will lock.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Quote Originally Posted by EHesh14 View Post
    Shit was just going to ask this exact question, previous own did it thou, not me. Can we replace the clear plastic piece on the front?
    Sent from my SM-G900V using Tapatalk
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Apr 04 2013
    Bartlett, IL
    Quote Originally Posted by quietcropduster View Post
    Multiple products made for removing fine scratches on the plastic instrument cluster cover, here is a good thread with numerous product recommendations......
    http://www.autogeekonline.net/forum/...-clusters.html
    2002 Corvette Z06
    Feb 21 2015
    Ohio
    Quote Originally Posted by MVR 155 View Post
    Tried a few of those it helps but not entirely and I'm ocd as fuck, it's eating st me lol
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    No, new cluster mileage has to be programmed. Dealer can adjust mileage of the new cluster, hackers can adjust mileage of used one also(carprog, enigma tool etc).
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Oct 21 2012
    Earth...
    Yes you can replace only front face, but you need donor cluster, as the face is not separate part in catalogue.
    http://www.audizine.com/forum/showth...etrofit-for-A4
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    I appreciate the hijack of my thread...
    But again, any removal instructions etc.. would be nice as well. :) I can't see that youtube video for some reason, maybe something at work. But as soon as I can ill check it. If anyone has anything relevant to the B8 (not 8.5 unless exactly the same) please post up.
    Is there anyone in Orlando or close by that has removed one, that I could pay to remove and put back in?
    **Watched youtube video and that isn't the same as my S4** I am looking for something that show's the removal from a B8 s4 so it's 100% relevant.
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Quote Originally Posted by KissMySSSSS View Post
    A few of us have swapped clusters in our A4s, same process. Here are a couple of good things with info:
    http://www.audizine.com/forum/showth...1#post11851028
    If you swap a cluster completely it'll run in safe mode and need to be taken off at a dealer. Only the speedo and mileage will work at that point, everything else on the cluster won't function.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Quote Originally Posted by shaunm82 View Post
    Gotcha... well I found some places that repair clusters. So maybe I can just send mine out and what not. :)
    Still hopeful that someone on the forum lives in Florida and has done this on a B8... I don't feel comfortable doing it since no one has a B8 video etc... Ill look at those in a bit when I get to work.
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Okay! That second link is hopeful! Now I need a pry tool. But as I said I am clumsy and brake stuff (especially clips!)... Wondering how much of a pain in the ass those panels are to get off because yesterday I applied a bit of pressure with my fingers and they didn't want to budge. (scratches head)
    Very good post though! Now if I can find a video lol..
    Jan 22 2016
    Audi TT and Touareg
    Orlando, FL
    Bump! Anyone have any videos of the B8 S4 / A4 Dash removal? (Not any other make) This exact model for removing dash? OR is there anyone near Orlando / Lake Mary that I could pay to pull it?
    Apr 05 2016
    Portland, OR
    Dash trim wasn't hard to remove but get the plastic pry tools they will save you a lot of headaches.
    With those you just have to commit, the clips take more force than I'd like to remove but aren't awful.
    Senior Member Three Rings hmc2261's Avatar
    Nov 25 2019
    Charlotte, NC
    Ok, this is a thread revival but I am thinking on replacing my cluster in my b8.5 because I have an LED going out behind the tachometer. Id like to also use the opportunity to swap it for the B8 cluster to get the 200 MPH instead of the 160.
    It looks like I can buy a cluster, install it and then go to the dealership to get it programmed or pay some guy to remote in to program it.
    Is that all id need to do?
    May 01 2017
    Seattle/WA
    hey i have a light going out as well! I'd be curious if it could be done via vagcom
    Oct 21 2012
    Earth...
    Quote Originally Posted by hmc2261 View Post
    Front and back "trim" is also different and dealer cant adjust mileage of used cluster. Not sure will pre fl cluster software show ads settings!
    Oct 21 2012
    Earth...
    Quote Originally Posted by SCHOUGY View Post
    No.
    Nov 20 2015
    West Palm Beach FL
    I went through a cluster “swap” about a year ago (i just facelifted the interior). If you’re going to go to a b8 cluster just swap the housing over from the b8.5. The internals fit and this way you don’t have to change the bracket it mounts to. You’ll have to change the needle covers if you want to keep the brushed look.
    As far as programming, the dealer won’t re-program a used cluster.
