Results 1 to 11 of 11
    Established Member Two Rings K2R1D3R's Avatar
    Jun 16 2015
    NorCal
    Help! Engine Oil Cap Under High Suction
    Don't know anyone local that I could compare my S4 to so I decided to ask the community! When my car is idling and I go to take off the oil cap it is under some pretty strong suction. Then when I go to put the cap back on after about 5 sec, the engine almost shuts off but then gets up and going again. What could be causing this?
    2015 Audi A3 TDI
    2012 VW Golf TDI (sold)
    2014 Audi S4 Moonlight Blue (sold)
    2013 Audi S4 White (sold)
    2001 Porsche Boxster S (sold)
    2007 Audi A4 (sold)
    Apr 11 2012
    Jun 16 2015
    NorCal
    Quote Originally Posted by will13k7 View Post
    Come on I'm clueless here man! Hah
    2015 Audi A3 TDI
    2007 Audi A4 (sold)
    May 10 2012
    2013 s4, 2008 cbr1000rr
    United States
    Jun 16 2015
    NorCal
    Thanks!!
    2015 Audi A3 TDI
    2007 Audi A4 (sold)
    Jun 16 2015
    NorCal
    I did not know that. Thanks for the advise! But I'm curious as to why not?
    2015 Audi A3 TDI
    2007 Audi A4 (sold)
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    I just replaced the PCV and mine sucks down and idles badly once removed... ignore the comments by old guy in that thread, the general consensus is that it is functioning correctly
    Jun 28 2016
    US
    Quote Originally Posted by K2R1D3R View Post
    Cuz it's not the right thing to do. You don't add oil while the engine is running. You don't take the cap off while the engine is running. Some diagnostic routines can involve this, but it's not something you wanna do as standard practice. The cap is designed to stay on while the engine is running and if you wanna check oil or add oil, you do it with the engine off, simple as that. After all, you did state that you don't know anything in the OP, right? I'm just saying... don't do it.
    And when you top off the oil, this is the right procedure either... lol
    Jun 16 2015
    NorCal
    Oh no I wasn't trying to add oil. I wanted to peek into the engine to see how clean, or dirty, it was just out of curiosity and that's when I came across the suction "issue".
    2015 Audi A3 TDI
    2007 Audi A4 (sold)
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Wow interesting that you posted this. Mine was found to be holding about 17 psi. The tech could barely get the oil cap off. I had the pcv replaced which helped this issue (now at 4-5psi). However it did not help my original idle issue. Currently trying to figure out what else is causing this. Do you have idle issues?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Jun 16 2015
    NorCal
    Quote Originally Posted by Hofahome View Post
    Thanks for the reply! I do not have an idle issue. Seems to idle fine.
    2015 Audi A3 TDI
    2007 Audi A4 (sold)
