Results 1 to 6 of 6
    Oct 16 2016
    PA
    A4 hit, left marks, need help deciding what to do
    Hi all,
    So these scratches have been on my car for a bit now, it was estimated at around 1,000 to have a body shop fix it. Frankly at the current moment, although I could afford it, that just isn't the best use of my money! However I would love to try and fix it up atleast a little better myself. I was going to order Dr.paintchip for rock chips, and was wondering if that would also work with this? I would need to sand it or something aswell! Anyone have any experience or ideas I could try?
    Here are some photos!
    http://imgur.com/a/XfDjU
    MUCH appreciated,
    Senior Member Two Rings rdenivo's Avatar
    Jan 05 2016
    2011 VW Tiguan
    I've had luck with 3M Scratch Remove, http://www.autogeek.net/3m-scratch-remover.html#reviews, to get ride of the scrapes.
    I've also used Dr. Colorchip for small rock chips. It won't match 100% but for $60 it's worth a shot.
    2015 A4, Scuba Metallic Blue, Eurocode Front and Rear Sway bars, Chrome delete, Partial Air Leather FBSW, Black S-Line and Audi badges, 19" Satin black 10 spoke rims
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    Might be best to try a good detailer to try maybe a fine wet sand them compound and Polish back to clear.. may not be perfect but close... Next step would be a repaint..
    Where in pa are you?
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Since this is not an Audi specific issue, you can find many, many you tube videos on various techniques to address the damage. With some color matched spray paint and right sanding/polishing techniques, you can get a result that will be quite acceptable..at least as an interim fix until you are ready to have a pro do a repaint.
    2011 A4 Avant
    Oct 16 2016
    PA
    How much do you estimate that would cost? Central PA
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    The fender has a dent?
    Can say to 99% it wont look good If you "fix" this yourself. Since you ask how to, it wont look good :)
