Results 1 to 8 of 8
    Established Member Two Rings RWLib3's Avatar
    May 28 2005
    Roseville
    SOLD - Chipwerke S - B8 and up S4
    Nov 09 2016
    IL
    I might be interested, location? I am sure this would fit in a flat rate box or something cheap.
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Dang I just bought one for $350.00
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Quote Originally Posted by 4Rings3Liters View Post
    You bought the pro, that's about the right price. This is the s version. Difference? No idea.
    May 28 2005
    Roseville
    There's a great post about the difference... here: http://www.audizine.com/forum/showth...rke-piggy-back
    What is the difference between the "S" model and the "Pro" model?
    The S model uses a plastic case. The Pro model uses an aluminum case.
    The manufacturer claims the S model uses an 8 bit microprecessor and the Pro model uses a 32 bit processor and claims a small increase in power consequently. This cannot be confirmed or denied because the internal board is potted and cannot be seen.
    May 28 2005
    Roseville
    Quote Originally Posted by MOORE'S4 View Post
    Located in NorCal. Should fit in a flat rate box. Its pretty small.
    Jul 04 2008
    York, PA
    Quote Originally Posted by mintytoo View Post
    Good call, still a good price.
    Feb 25 2014
    windsor, ca
    yep good price. and good post on the difference between the two. its the same unit as racechip.com , just rebranded for them
