Results 1 to 14 of 14
    Established Member Two Rings Chr1sJohnson's Avatar
    Sep 28 2007
    07 Audi Q7, 83 CJ7, 07 Harley Night Rod, 67 Triumph Bonneville
    Charlotte, NC
    APR Stage 3 ECU Adjustments?
    Hi,
    Not sure if this has been addressed before, but is the APR Software customizable? As I mean.. are there options to further push numbers beyond what has been set as default through the programs that were flashed on my car when my Stage 3 kit was installed? I know there are other vendors out there that offer Tuning programs for our car, but wasn't sure if APR has such thing, or if I had the option to alter any of the settings within the APR tune itself? I know APR has suggested modes for the car when you flash it, but you never know....
    Thanks in advance.
    APR Stage 3(Carbonio Carbon Fiber Air Box, MAF Housing, Turbo Compressor Inlet Hose, Diverter Valve Adaptor, Garrett Turbocharger, Oil/Coolant Lines, Compressor Outlet Hose, High Pressure Fuel Pump, FSI Fuel Injectors, Exhaust Manifold, Exhaust Downpipe), Brembro 6 piston, 4 piston, Bilstein PSS10, S5 Wheels, Magnaflow 16601, H&R Sways, RS4 Interior trim, RS4 Pedals, RS4 Shifter, Excelon DNX9980HD, Hertz HSK165, Kicker 1000.1 ZX, L7 12", IX 1000.5
    Jun 17 2013
    jersey city nj
    APR specific tune parameters are set in stone . There are update versions available to a point. Just make sure you have the latest revision. If you to squeeze every drop of HP out of the Stage 3 BT set up. Your gonna have to @ other tune vendors
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    They may have a race file for 100oct fuel that is switchable. Just make sure you are running 100oct fuel.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Jun 17 2013
    jersey city nj
    Or a meth kit that will give pump gas that 100 octane equivalent
    Jun 27 2011
    Or switch to a tune that isn't crap like APR.
    Just sayin....
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jun 17 2013
    jersey city nj
    Just sayin....
    I wouldnt say its ty. Just conservative
    Jun 27 2011
    Well yea I guess. Their stage 3 hardware is solid. Their manifolds are top notch. But their tuning, until very recently, has always been just decent.
    I shouldn't crap on them too much, I actually really liked my APR Stage 1+ tune on my b6, but tuners like Motoza can offer more features and better tunes for less. APR is the safe choice I suppose.
    -CP
    2017 Q7 3.0t
    May 09 2012
    Virginia
    Both APR and AWE/GIAC offered their stage 3 kits with a gt2871r turbo setup. They are both conservative in that the gt28 framed turbos have the potential to create more torque/power than what was felt to be safe for stock rods. The goal for both of these vendors was reliability and safety (not throwing a rod). I am currently running the AWE kit, however I built the bottom end with I.E. rods and am now pushing the turbo and tuning more. You can definitely extract more from these setups just need to make the appropriate modifications.
    Jun 04 2011
    Clayton, CA
    Quote Originally Posted by jbain2 View Post
    Who are you tuning through now?
    Build Thread
    Sep 28 2007
    Charlotte, NC
    When you say you are tuning more, what are you using to further tune your car outside of what the APR/AWE recommended specs are programmed into the ECU.
    May 09 2012
    Virginia
    Quote Originally Posted by Chr1sJohnson View Post
    I am working with someone on custom tuning. I log several parameters with Vag-Com over WOT runs to redline. Look at fueling, timing, intake and exhaust temps as well as boost.
    Sep 28 2007
    Charlotte, NC
    Any updates with the custom tuning? What are you using to adjusting your tune? Would love to get more out of my APR setup.
    May 09 2012
    Virginia
    PM sent
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    You can always get maestro and do your own tune.
