Results 1 to 4 of 4
Thread: Oil pressure
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Oil pressure
    Hey guys so im looking to change my oil pressure sensor in my C5 and on ecs theres two parts: the oil pressure sender and oil pressure switch. I just wanted to know if they are different parts or what do i need?
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    are you after the bit on the underside of the oil pan?
    if so, then the sensor
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Sep 17 2014
    New York City
    Quote Originally Posted by PaperToast View Post
    Isnt that the oil level/ oil temp sensor? If your oil pressure switch went bad your dash would turn bright red and flash a picture of dripping oil while beeping.
    They look to be the same thing with different names. One for 1999 and before and one for 2000 and up.
    Jun 21 2015
    LI, NY
    Yeah the one that causes the error message in the cluster. Upon looking further i feel pretty dumb, they seem identical but just different names.
    01.5 B5 S4 6MT SOLD
