Results 1 to 7 of 7
    Veteran Member Four Rings blai76's Avatar
    Aug 25 2011
    planes, trains and automobiles.
    San Francisco, CA
    JHM ECU Tune question
    My search skills are lacking today and I haven't been able to find it, so I'm just going to ask here. Is there some information accessible in VCDS that will allow me to determine if my JHM ECU tune is still present? Troubleshooting something emissions-related and wanted to double check my flash is still present. It drives like it is, but I wanted to be sure.
    Bob
    2008 B7S4tip Avant, 1998.5 B5A4tip 2.8L V6 (retired)
    Active Member Two Rings BugAudi1's Avatar
    Apr 01 2015
    88' Scirocco
    TX
    I just emailed them about it the other day.
    Dru at JHM says: "If you have a Vag-Com Cable you can tell by clicking on ECU and looking at the component name. It should say JHM in the title. You can also provide me the VIN and I can try to see if I can figure it out."
    Sent from my SCH-I605 using Tapatalk
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    I've forgotten exactly how it shows, but it say something something dark side.
    Just kidding - it's something something 4.7
    Aug 25 2011
    San Francisco, CA
    Thanks, guys.
    Bob
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    You can PM me a screen shot and I will tell you.
    What makes you think it is gone? Did you take it to a dealer and they may have written to your ECU??
    Aug 25 2011
    San Francisco, CA
    I had work done to correct a cel related to a bad purge valve. I just wanted to be sure, as I'm running into the stupid catalyst not ready issue with smog testing. I've done two 200 mile drives in the last four days, and I tried the drive cycle instructions from the bentley manual without any luck several times, and I'm honestly just grasping at straws.
    Bob
    Aug 31 2011
    Lathrop
    Quote Originally Posted by blai76 View Post
    Are you able to bring it in to us for diagnostics?
