Results 1 to 2 of 2
    Dec 03 2010
    Connecticut
    How to best refresh a 4.2L
    I recently purchased a part-out Allroad. I will be putting the motor from that into my car. I can't have my DD down for very long, so I need to do a lot of work/pre-planning and perform the swap within a one week period. The part-out car has 200K. I was told that the motor was replaced (reman) at 100K, however I don't have any way of proving that. The motor does blow some (pretty foul smelling) blackish smoke when I rev it up. Never when it's just idling. I'd appreciate suggestions as to what I should look at when I pull this motor. Here's my (short) list:
    1.) Timing chain guides and chains. The motor is not making any timing noise what-so-ever, but I will probably inspect/replace just to be safe.
    2.) Power steering pump is whining, it is most likely original (200K) so I will replace this.
    3.) A/C pump? Have read something about lubricating it in some way? Clutch inspection?
    4.) I don't know how these Audi motors are constructed, but are there valve seals and should I consider replacing them? Maybe have the heads warmed over at a local shop? I would prefer to do all the work myself. If there's traditional valve seals I'll take a crack at those unless too many expensive specialty tools are needed.
    Thinking I will do a compression test before I pull the motor out. Any other suggestions? Weak points of the motor etc? I'd like to buy a rebuild/repair guide if one is available.
    Established Member Two Rings RHawk's Avatar
    Feb 23 2018
    '19 Subaru WRX
    Mundelein, il
    I'm right there too! My 05 s4 needs a freshen up, and I'm looking for any advice to stop massive oil consumption. My chains were done 20K ago, but nobody thought to freshen up the motor or heads.
    Sent from my HTC6535LVW using Audizine mobile app
