Originally Posted by
IowaRS7
Went to a midnight track event last night and finally had a chance to run my car with the Sunoco 104oct fuel.
1st of congrats, that's a good pass
IowaRS7
Outside temps were unusually cold (60s) for this time of year making traction on a cold track the biggest issue. You can certainly tell a major difference with and without AMAX!!
looks like upper 60's which shouldn't normally be an issue for traction and your 1.61 60'/4.419 330 and 106mph 1/8th seem to indicate you were planted pretty well. Amax is massive, generally .3-.5 sec.
IowaRS7
Really hope to see an updated APR ECU and ZF tune at some point.
just curious what you're hoping for from a TCU file, I've done a lot of investigating and there's no evidence I can find that a TCU file will do anything to make our cars faster from a straight line standpoint. And for those hoping AMAX can be engaged from a roll, it can't, APR and EC have ruled that out.
IowaRS7
Going to look into the inlets now and continue to follow SRM and Eurocode’s work. Some GTX30 billet turbos with better cooling would be nice
SRM Sean (among others) is doing great work in coming up with solutions to our issues, mainly because he's an owner as well as a fab guy. The biggest improvements needed, as you alluded to, are in the cooling, and the bigger hybrids for sure cause a lot more heat. I'd be inclined to look at the stage 1 cooling upgrade he's got first, it's a solution I been privy to some inside information about and it works, even on a stock turbo car. The GT28/30 upgrade I think will need some more time to prove itself and I for one am living vicariously through my buddy who's proving the GT28's work, but regrettably he snapped and axle a couple weeks ago so with the extra power comes consequences. There is as much movement in the platform now as I've ever seen so it's an exciting time to be a S/RS 4.0TT owner.
