Results 1 to 11 of 11
    Veteran Member Three Rings JAudi23's Avatar
    Oct 31 2013
    2003 Audi A4 3.0 Quattro 2004 Audi A4 Avant 1.8T FWD & 2000 Kawasaki Ninja ZX-6R
    Milton, ON, CA
    Drivers Side Engine Cover Retrofit Mounting Points
    I have started to custom retrofit a drivers side engine cover (part # 8E0 103 927 C) on my 1.8T that came from what I believe was the V6 3.0L model.
    I still have a bit of trimming work to do around some of the hoses before I can permanently install it however.
    I am hoping someone can help provide me some photos of an original 3.0L engine bay with the drivers side engine cover REMOVED.
    For comparison, this is the driver's side of my engine bay right now without the cover.
    If you can post or send me some clear photos through PM it would be greatly appreciated. I am trying to see where a couple of the mounting points fasten on an original setup, so I can fabricate some brackets to make it work in my car.
    I'd like to see a close up of the connection points for the 2 mount points circled in the below photo of the underside of the cover.
    IMG]https://uploads.tapatalk-cdn.com/20161114/5acd9cab9a8b570b1af02b50e90fe005.jpg[/IMG]
    At first glance, I am thinking that the coolant overflow reservoir is a different part # on the 3.0L models which would make sense for where the cover snaps into the ball head bolt. (#17 in this screenshot from ETKA which is not clear on this part for the various models.)
    For the front connection point, I see the cover has a curved part that will sit over a bolt to secure that, but I do not see anything on the front body near the radiator, where it could screw into.
    Thanks in advance for whoever can help me with this.
    2003 Audi A4 3.0 Quattro, Brilliant Black
    Custom 12V USB Socket | ProClip Mount | Curt Mftg Hitch | Thinkware F800Pro Dashcam
    Retrofits:B7 Center Console Swap | RNS-E
    SOLD - 2004 Audi A4 Avant 1.8T FrontTrak, Light Silver Metallic
    Nov 03 2011
    All Over!
    I'll take a picture of mine, with the engine cover removed. From memory, you need a different coolant expansion tank, as one of the retainers is actually screwed to it.
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    This is mine - 2003 3.0 Avant Quattro Sport. As you can see, the 3.0 coolant reservoir is different, it has the extra tab, to screw the ball-ended mount into. You could possibly fabricate something, but personally I would get a 3.0 coolant reservoir, for a clean, OEM look:
    Oct 31 2013
    Milton, ON, CA
    Thanks Nollywood!
    Once confirmed I was considering just replacing the tank. Now I know for sure.
    Can you snap a pic if the front mounting point near the radiator? (No rush)
    Sent from my SM-G925W8 using Tapatalk
    Nov 03 2011
    All Over!
    No worries. I'll snap a picture, it'll be tomorrow though, as by the time I get home, it'll be pitch black!
    Mar 21 2016
    69 Nova
    California
    JAudi23, what's that shiny thing below the ABS module and to the left of the power steering reservoir?
    I was always curious why I had an empty space there, apparently it's something only for 1.8T guys...
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by DarkoNova View Post
    brake booster vacuum pump found in auto transmission cars.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Oct 31 2013
    Milton, ON, CA
    Quote Originally Posted by blitz2190 View Post
    Darn Blitz2190, I was gonna tell DarkoNova it was my super top secret NOS booster, but yes it is indeed a Brake Vacuum Pump found only on Automatics. Mine however periodically blows a small fuse, and i never notice a difference in breaking force. Need to look into that further one of these days.
    Jul 31 2014
    NH
    Quote Originally Posted by JAudi23 View Post
    lol a 10 shot :p
    Mar 21 2016
    69 Nova
    California
    Ah, interesting.
    Thanks guys :)
    19 Sportster 883
    Oct 31 2013
    Milton, ON, CA
    Bump, just to send a gentle reminder on the picture. Thanks!
    Sent from my GT-P5210 using Tapatalk
