Results 1 to 4 of 4
    Active Member Two Rings euroocrew's Avatar
    Aug 31 2016
    Corona CA
    Need help 2009 Audi A4 misfire
    Las night I went over a speed bump and after wards heard a loud pitch noise (weird I know)
    Popped the hood and it seemed to be coming from the engine near the throttle body
    This morning I turned it on the high pitch noise is gone but the car is misfiring
    And throwing codes
    P0300 , P03001 , P03002 , P03004
    I'm leaning more towards a bad throttle body , or would it just be bad spark plugs and coils?
    Any help would be appreciated
    Aug 27 2016
    Houston
    Anythibg you do make it even out? Throttle while idle, throttle while accelerating etc?
    Established Member Two Rings Dr. Awesome's Avatar
    Aug 22 2014
    2009 Chevy Silverado, 2011 Yamaha FZ8
    United States
    No expert here, but you could look at PCV valve as well. I was reading on this earlier and people have reported misfire codes among various others along with some cases of a whistling sound. You can check easily by opening the oil cap, just look up some videos. Easy fix if that is the problem, if yours hasn't been replaced, it would be good to do anyway!
    Aug 31 2016
    Corona CA
    Just an update, it turns out the PCV valve went out and would cause a misfire (very common on b8's )
    Easy fix though on the 2.0 engines
    Part was 80$ OEM and took about 20min to install
