Originally Posted by
PKmode
Err. It WILL lock up your tires. I have done it at speed. If under 5mph, it only locks up the rear wheels. If over 5mph, all four corners will lock. Due to this, there is no fun to be had engaging the parking brake in an attempt to slide the car.
Also, there was semi recently a video of someone here who had the parking brake engaged after a launch and when he let off the gas, the car screeched to a halt.
If you're at speed, and you engage it, it should not lock up your tires. I've tested this many times in both my S4 and S6. At speed, the car engages emergency braking mode, which brakes as fast as it can with all 4 wheels before ABS engages.
If you're stopped, it will act as a normal parking brake and lock up the rear wheels. If you're stopped, and start going without disengaging the parking brake, it will continue to function as a parking brake. The video you are talking about shows this. The launch was abnormally slow, and the general consensus was that the inexperienced driver left the parking brake on while doing a launch. Once they let off the gas pedal, the parking brake locked the rear wheels and the car screeched to a halt.
The only thing that video didn't explain is how the parking brake did not disengage itself. In every situation I've tested, my parking brake has disengaged itself as soon as there was enough load on the engine to get moving. It's possible the driver did not have their seat belt on, which may have caused the parking brake to not disengage.
