Results 1 to 6 of 6
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    2001 Audi s4 avant stage 3 152k $8k
    Looking to sell outright or trade for a clean nogaro/nogaro sedan
    2001 audi s4 avant stage 3
    6 speed
    153000 mi.
    clean title
    Good stuff:
    stage 3 @137k
    BW RS4 turbos and inlets
    ASP Stage 3 fueling kit (injectors, MAF, FPR, ECM software)
    AWE intercoolers and shrouds
    Full SSAC 2.5" catted V2 downpipes, full exhaust
    K&N drop in filter
    Bosch 710n diverters
    Samco silicone/kevlar TBB
    RS4 clutch with upgraded pressure plate
    034 street engine mounts
    poly snub mount
    RS4 transmission mounts
    RS4 perforated leather shift knob
    Vast short shifter
    custom vent boost gauge
    Replaced display in instrument cluster, gauge trim
    Matte black RS4 door pulls
    RS4 front grill
    RS4 rear spoiler (paint job is not best nor is the current fitment)
    RNS-E Nav unit
    Vogtland coilovers (little rusty and collars are not in the best of shape)
    Neuspeed rear swaybar and subframe reinforcement brackets, upgraded metal links
    lower control arms and aluminum wheel bearing housings/knuckles
    18" RS4 reps et35 235/40/18 tires
    All season oem rubber floor mats
    Carpeted oem trunk liner
    Some custom led interior lighting - red lighted door pulls glovebox latch, white lit door pockets, under door puddle lights
    Custom ecode headlights
    European taillights with amber turn signals
    B7 rearview mirror, newer outer mirrors
    Passat aero wiper conversion and rear aero wiper
    Komfortblinker tap to flash 3x or 5x
    recently replaced rear drivers side brake caliper and rear brake pads, hawk HPS front brake pads, front drivers side inner and outer cv boots, spark plugs, mobil one european car blend 0w-40 oil change and mann oil filter
    rear child seat latch system installed on both rear seats that i may keep
    25% tint on all windows except windshield
    The bad:
    The usual dings, dents, scrapes, wear and tear you might expect
    brake light comes on dash every now and then but goes away. I'm looking into it
    Front bumper is banged up. has a crack on lower passenger side and bottom center grill area was bondoed
    Front passenger fender has some rust and was rolled too thin looks like poop (i am in the process of finding one from a part out to switch out)
    Front Drivers side door has some rust near trim moulding
    Small rust spot on trunk hatch the size of a quarter
    Small dent on passenger side rear quarter panel
    rear strut towers and rear subframe rear control arms have some rust......Northeastern S4
    $8k Lehigh Valley PA
    May 03 2016
    Nc
    Wish I had the cash
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Bump
    Established Member Two Rings Trendsetter's Avatar
    Apr 03 2010
    Zurich, Switzerland
    Is it on the original motor? ever been rebuilt?
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Original motor
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Bump
