Hey I recently picked up a 2010 A4 with 60k miles and more or less I love it. Came from a 13 GLI that was in an accident so needed something quick and cheaper than what I spent on the GLI wish it were 6MT but couldn't spend a ton of time searching.
I just replaced the PCV due to a check engine light and the codes I got on VCDS. Also changed the oil and cleared codes and 100 miles later I'm still good, so I think I solved the issue.
But while replacing the PCV I noticed a few things that I've kinda put on my list of repairs. Forgive my lack of knowledge of terminology here.
1 - On the Coil Pack Wiring Harness theres those little clips that come out and clip into well I dunno, but its the little clips and wires coming out the opposite side of the coil packs. When I replaced my PCV I noticed that the clips themselves were half broken I assume from a previous owner as this was my first time under the hood. I'm wondering if there's any DIY's on replacing these clips or the harness itself. I can't seem to find a part for this searching through a few of the common sites.
2 - I believe oil was leaking into where the coil packs were because when I removed them I found some residue on the sides. I plan on replacing these with R8 Coil Packs to give me some piece of mind. But 2 questions here, should I replace the plugs at the same time? I'm thinking I may as well while I'm working on it. And is there any safe way to clean the insides of where the coil packs and plugs go? I'd like to remove any other oil residue.
3 - Oil catch can worth it?
4 - When changing the oil I noticed that the screws holding the plastic cover in place were half missing and the remaining ones were stripped/corroded. Anyone have a part number for these screws? Or am I overthinking it here and should just go to autozone and tell em what I need.
Just trying to keep the car straight while I make it through the winter, then hopefully starting some more fun stuff.
