Results 1 to 19 of 19
    Veteran Member Three Rings Karbon's Avatar
    Oct 04 2016
    New York
    Bilstein B16 Ride Control Coilover System
    From what Bilstein is stating,Dampening is adjustable using the Magride control in the car.. Would this eliminate any possible codes using the regular B16s that everyone is running with the KW delete kit ? I thought all coilovers for our cars had to delete mag ride
    https://www.ecstuning.com/b-bilstein...49-231892~bil/
    2010 ZR1 - 9.5 @ 151
    2013 CTS-V - 9.8 @ 141
    2005 EVO - 9.6 @ 149
    The Ride Control system has a button and an optional Phone App which allows you to change the settings. It doesn't integrate with the factory Suspension so you still need the KW Delete Kit.
    Bilstein is coming out with a Damptronic option, at least for the Golf R, which would integrate with the OEM suspension control. This has not been confirmed for the S3, though. The Golf R DCC is not the same as MagRide.
    His: #samoas3 | 2016 S3 | P+ | Audi Exclusive Samoa Orange | GIAC Stage 2 + TCU | Neuspeed | 034Motorsport | CTS Turbo | HG-Motorsport | Neuspeed RSe102 19x9 et40 *138.8 MPH Half-Mile*
    Hers: #lavasq5 | 2014 SQ5 | P+ | Lava Gray Pearl | AWE/GIAC Stage 2 | KW | SPC | 034Motorsport | AWE | RS Grille | 285/30ZR22 on DPE CS5S 22x10 et22/26
    Oct 04 2016
    New York
    That's stupid then,considering they charge $800 more for a app to control it inside the car. I wish they had something like that currently. Ill keep my eyes open to see if they release anything for the S3.
    Thanks
    Nov 17 2014
    San Francisco, CA
    @karbon, I have the ride control now. To use the app, you'd need the IRC which changes the ride modes automatically based on accelerometer inputs... Its an additional $300 or so, but personally not really worth it as 95% of the time you will be in comfort mode.
    Haven't seen any systems which integrate with ADS, however been trying to crack the canbus signals from the car too allow the cars to do so.
    More install info along with how I put my switch in the car.
    http://www.audiworld.com/forums/audi.../#post24694004
    http://www.audiworld.com/forums/audi.../#post24702698
    Sent from my SM-N910V using Tapatalk
    Sep 28 2010
    NW NC / DE
    What about the KW DDC? I also just saw the Bilstein B14. I assume they're similar to the H&R street.
    I can get with Bilstein on the DDC for the S3 if you like.
    Oct 04 2016
    New York
    Quote Originally Posted by mroberte View Post
    Nice videos and I appreciate the feedback. The only reason I even considered them was because I thought they integrated with the factory mag ride. I don't really want to deal with the lights coming on the dash,But Im going to have to live with it.
    The KW kit that works with DDC I believe is only a 1.2" drop and that isn't enough. 50mm is the least I would do,Only ST and vmax seem to have a 60-65mm drop.
    Call bilstein and get them to make a kit if you have it like that lol - I wanted to buy them today tho :)
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Quote Originally Posted by Karbon View Post
    The KW kit for the DCC only drops to 1.2" because that's what the car is happy with (ride control codes). That is also why their delete module doesn't play nice when going past a certain height.
    Oct 04 2016
    New York
    Quote Originally Posted by Excelerate Rep View Post
    That makes sense,Considering that's what super sports drop the car to as well with no lights.
    I'm still on the fence,I really want Air but I'm not sure if I want to spend 4-5k on suspension right now.
    Sep 28 2010
    NW NC / DE
    Ha, I certainly do not have it like that. Just saying I could hit up my guy at Bilstein for info on an incoming kit.
    Oct 04 2016
    New York
    That would be good and probably very helpful,If not for me for other members.. I'm going to order something today or tommorrow,I just want to make sure i pick the best setup.
    I originally wanted Bilstein B16s because everyone is saying they ride great,However having no camber plates on the front and only offering a 1.9" drop has pushed me to look at other setups.
    What do you think of the ST XTA's ?
    2.2 drop in rear, 2.4 in front and front camber plates for $1360.. Hard to beat,But i've never been in a car with them.. KW makes them so that definitely gives me a bit more confidence in them
    Apr 11 2012
    I've heard this from KW too, but there is a guy with the KW KV1 kit that get codes:
    http://forums.vwvortex.com/showthrea...#post101161441
    From his description of being "dumped", he probably spun the coils all the way down, past the recommended ride height, but that's a 1.2" drop.
    Sep 28 2010
    NW NC / DE
    Yepper, email sent!
    Not too familiar, so I hate to comment. "Soft" comes to mind from past experience on B8 cars, but these are damp adjust. Probably pretty good. I'll look out for your order ;)
    Oct 04 2016
    New York
    Ha Thanks man! Ill do some more resarch on them before ordering!
    I contacted a vendor to confirm the drop for the ST's,Since it could be for a A3 and not S3.. And they said if i'm looking for a "large" Drop i should go with H&R Street coilovers,As ST is not ideal for a low setup
    According to ED's site tho,It's only low on A3's..
    A3: 1.5" - 2.3" Front & 1.5" - 2.5" Rear
    A3 Quattro: 1.5" - 2.3" Front & 1.5" - 2.5" Rear
    S3: 1.0" - 1.75 Front & 1.0" - 2.0" Rear*
    Sep 28 2010
    NW NC / DE
    My A5 was on Streets for 5 years. Loved them. And I was low, and had room. You saw it. @Karbon
    Established Member Two Rings sandjunky's Avatar
    Sep 12 2016
    Push mower and RC cars
    Lincoln/ca
    Do you remember how many turns you had on that setup? Trying to gauge a staring point.
    Veteran Member Four Rings HBird's Avatar
    Jul 18 2015
    2019 Ranger, 2023 4Runner
    Snohomish, WA
    There's a Damptronic coilover that's coming out next year as well as a strut compatible with cars with built in adjustable dampers. There's a popular thread in the Mk7 R section of Vortex about it, but I'm not sure if it'll make it for the S3. I don't know why it wouldn't though since it's pretty much replacing the entire strut assembly.
    - Hunter
    I got me a Ferd now
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by sandjunky View Post
    I recall being about 80% down, but I may have pics. I'll dig through my cell in a bit. Over 10K pics lol
    Sep 28 2010
    NW NC / DE
    @Karbon - The Bilstein DDC Damptronic drops early this Spring.
    Oct 04 2016
    New York
    I appreciate the follow up ! Still on the fence on which setup I want to go with :(
