Thread: ECM replacement
    Senior Member Two Rings jwr9152's Avatar
    Apr 08 2015
    Pensacola, Florida
    ECM replacement
    My ECM is going out, and needs to be replaced. Does anyone know if you can program a used ECM or do you have to get a new ECM? I've heard different stories.
    Established Member Two Rings Siopao's Avatar
    Aug 22 2016
    2019 A7 2021 Q7 (wifey)
    Houston, TX
    You can attempt to program a used one but short of saying your gambling hoping the program takes and doesnt have issues. Thats what my indie says. Going through this with my beater passat. Tried rewiring my throttle body and possibly may have shorted my ecu.
    2013 S5 | TSW Portier 20x10 | AWE track exhaust w/resonated dp | P3 gauge | Revo stage 1+ | roc euro intake | Revo charge cooler package | DSG tune
    Apr 08 2015
    Pensacola, Florida
    well crap, I was afraid of that. Thanks for the reply. Good luck with the passat.
    2011 S5 6 spd 4.2 V8 with APR stage 3 supercharger, APR tune, B&B exhaust, Bilstein PSS10 B16, 034 strut mounts, SPC adjustable control arms, USS sway bars and end links, JHM lightweight flywheel and clutch, Meisterwerk short shifter, 034 transmission mount, Stoptech BBK, carbotech xp12, alu kreuz, 034 intake, apikol differential mount, AWE S-flo filter, cr-15 strut brace, Advanti Hybris 19X9.5, Michelin Sport Cup 2 275/35/19. USP RS5 grill. 034 Motor Mounts
    Veteran Member Four Rings V8Star's Avatar
    Jun 08 2010
    You can use a used ecu, but only the dealership or an independent shop with the factory scan tool will be able to program it for you.
    Make sure the part number on the box matches the one currently in your car.
    R8 V10 Supercharged
    8V.2 RS3 grocery getter
    A few A4 Avants
    Apr 08 2015
    Pensacola, Florida
    Quote Originally Posted by V8Star View Post
    Really, that's great news. Saves about $1000.
