Results 1 to 18 of 18
Thread: 20-140 pull
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    20-140 pull
    Here is a pull with my car with 4 gallons e85 mixed with full tank of 93oct. and chipwerk set at 7-1. Rest of mods in sig.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Sweet! Do you have any logs from the Chipwerke on the 7-1 setting? Just curious because I'll be playing with that setting tomorrow on the factory map and dual pulley.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Strong pulls, it must have been a long road trip to mexico.
    How do you like the Stage 3 clutch with the OEM flywheel and i'm assuming OEM pressure plate? It looks like it holds in your videos. I'm due for a clutch replacement myself.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Nov 12 2006
    Michigan
    Quote Originally Posted by fitzydude View Post
    I do but I need to get them off my PC that is dying and get them on my Mac so I can share.
    Nov 12 2006
    Michigan
    Quote Originally Posted by jlaudio View Post
    I'm a big fan of this clutch, pretty smooth engagement but holds strong. Its the Spec stage 3 clutch and pressure plate. I had the same on my past B5 S4 running over 600hp with no slippage.
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    nice video man thanks
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Nice shift-a-roonies!
    Established Member Two Rings dean.mohr's Avatar
    May 11 2015
    '01 F150
    Toledo, Ohio
    Woah, that's fast! Especially over 100.
    2012 S4 Prestige // Ice Silver Metallic w/Lunar Silver Interior // 6MT // Titanium Package // Chipwerke Pro // CTS Turbo Intake // AWE Track Exhaust (105k)
    2001 Ford F-150...with 265k and counting!
    I'll Always Remember You: 2013 Ford Fusion Titanium
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by elijahallen View Post
    You running pre and post s/c meth? I may have to hit you up in the spring to help a little with setting up meth.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Apr 27 2015
    canada
    i'm not sure i'm familiar with that clutch but i don't know much about clutches so that's not surprising. Why did you go w/ a new o e m flywheel? jw, seems like most go w/ the lwflw when upgrading the clutch, is there benefit to staying o e m?
    Nov 12 2006
    Michigan
    Quote Originally Posted by Thurston View Post
    I've used lightweight flywheels in the past but like the drivability of the OEM and lightweights are general noisy and this is my daily driver so not all race car :)
    Nov 10 2014
    Apex, NC
    finally a video with a MT owner who doesn't sleep during shifts
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Stage 2 Banner Advertiser Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Wow I need to get off this Stage 2+ plateau and go dual pulley! I'm having that clutch installed this week with the ECS LWFW, glad to see a positive review of it!
    Nov 12 2006
    Michigan
    Quote Originally Posted by Hofahome View Post
    Just pre supercharger at this point. Its probably not doing much being setup this way.
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by jsh139 View Post
    Y u no like gear indicator?
    Seriously, though. Nice vid and results.
    Where is the option to turn that off? I remember seeing it once, but cannot find it anywhere now.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Car > Instrument Cluster > Shift Suggestion, I believe.
    Jan 26 2015
    CO
    You sure you didn't setup nitrous instead lol. I'd like to see some logs and if you get a chance.
