Results 1 to 9 of 9
    Nov 11 2016
    Sacramento/California/Rosemont
    2003 Audi a4 3.0 quattro
    Hey guys, so I just bought an Audi A4 3.0 quattro with 65K miles on it. Its in really good shape overall but I already did minor things to it like new brakes etc...I still got quite a few things to do but mainly how do I fix a transmission fluid leak from the rear differential and insecure anything I needa look out for like typical issues, bugs, etc while owning it? Thank you
    Sent from my HTC One A9 using Audizine mobile app
    Registered Member One Ring uro runner's Avatar
    Oct 06 2016
    north carolina
    03 with 65k? Almost time for timing belt if it hasnt been done already
    Sent from my SAMSUNG-SM-G891A using Audizine mobile app
    Nov 03 2011
    All Over!
    Rear differential oil leaks are usually due to tired shaft seals (driveshaft and axles). Not a massive job, both will involve removing the driveshaft and axles, after draining the oil, then replacing the seals, followed by reassembly, and filling with fresh oil.
    When you say "insecure", do you mean the differential has excessive movement? If yes, then it'll need replacement mounts.
    At 65,000 miles, your car is just 15,000 miles shy of a timing belt replacement. It's based upon mileage or time, so I would certainly be looking to replace it. Heart-stopping bills if it breaks in service.
    1986 Type 85 Audi 90 quattro
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Check this out: DIY-Rear-differential-axle-seals
    No need to mess with the outer end of each axle. See last post in link above.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    If the timing belt is original, you should change it now based on time, ignore the mileage.
    Sent from my Pixel XL
    Nov 11 2016
    Okay thanks y'all, I'll be definitely looking into that stuff.. and shall go ahead and purchase a timing belt as well 👌
    Jun 26 2015
    Tampa, FL
    Quote Originally Posted by Misha0415 View Post
    And a water pump, and a tensioner, and coolant. Get this for the coolant. You will need to add equal parts distilled water. DON'T use tap or bottled, just pay the 80 cents or water for a gallon of distilled water. Not sure exactly what parts you need for the timing belt change. It's different from the 1.8T that I have, but you don't want to only change the belt.
    Nov 11 2016
    Quote Originally Posted by rocket1420 View Post
    Haha definitely, I'm making a checklist so yea I'll add that
    Jun 26 2015
    Tampa, FL
    You probably also have front control arm replacements in the near future, along with engine mounts and snub mounts. I can't believe you found one with 65k. Take good care of her :).
