2002 B5 S4 - 155k miles
Silver
Manual
AWD
Asking: $4,500
Modifications: (“Stage 2”)
- GIAC chipped
- Custom intake
- Borla exhaust
- Short-throw shifter
- Wired for and includes amp and two 10” JL subs if buyer is interested
- Hardwired for Radar Detector
- OEM RS4 Grill
- Clear bra protecting front of car
- 20% tint all around
- Boost gauge
Spare parts included:
- 2 extra full-size wheels w/ tires
- brand new PCV updated spider hose system
- full aluminum trim (never got around to installing, currently has stock wood trim)
- VAG-COM cable, I can help you set this up if you’d like
- Original non-chipped ECU
I’ve had and loved this car for about 5 years since 60k miles. All repairs/maintenance have been done properly and timely with all records to pass on to next owner. Clutch/turbos going strong. Oil changes done religiously.
Reason for selling:
Financially I’ve needed to drive something newer and cheaper to maintain, so this is no longer my daily driver. The car has also been sitting for a few months due to some issues that need to be fixed before regular driving should resume. This car would be great for someone willing to put the time/money into fixing it, unfortunately I can’t.
I recently hunted down a misfire — checked coil packs, replaced spark plugs, and replaced both ICMs (ignition control modules) to correct the misfire. The car also has a coolant leak due to what I believe is a leaky valve-cover or head gasket. (I’m thinking it’s showing up suddenly now because I stopped driving the car for a while and the gaskets were no longer “swollen” or expanding to fill the gap - just a guess). Needs to be jumped to start but no noise from turbos and car still boosts/drives great. To clarify, here’s a summary:
Needs:
- Coolant leak (head gasket? - see above)
- New coolant line under reservoir
- Hood latch getting stuck closed, may need to replace? (this is why the grill is currently off in the photos)
- Passenger rear wheel bearing
- Battery replaced / checked
- Small scrape on side of car
- Body needs some minor touch-up (normal wear and tear for 14 year old car)
Recently replaced:
- Spark plugs
- Coolant reservoir
- Both ignition control modules
- Alternator
- HIDs
Asking: $4,500
The price reflects the car’s needs, please PM me if you have any questions.
(note the RS4 grill is not on in the photo due to hood latch issue above)
