160cc Big bore Custom Honda Ruckus
160cc Big bore kit Ruckus $4,100
Selling because I barely ride this thing, someone else should get to enjoy it.
I have over $4k invested in modifications alone. So you're pretty much getting the Ruckus for free haha
I?m located in Beaumont, Ca and I need a local sale.
Clean title in hand. It runs great and I?ve had it up to 71mph. Currently I have it tuned for more torque so it gets to 65mph pretty quickly.
I?m sure there?s a lot I?ve added that?s not on the list, but here is what I can remember so far?
Lowered seat frame
Double diamond stitched seat
Brake clutch/master cylinder
RRGS front shocks
Front disc brakes
Lowered Caf? Racer Handlebar
Password JDM handlebar clamp
Lowered rear shock
Aftermarket kickstand
12x4 front wheel
Aftermarket front wheel hub
12x8 rear wheel
Composimo rear wheel hub
Front shinko tire:
Rear shinko tire:
11 Pole stator
EFLR-1
Handle bar end mirror
Pegs
10x1.5 hex wheel bolts
GY6 150cc
160cc Big bore kit Taiwan 58.5mm
Mojo customs 12x8 GY6 mount with 12.5? stretch
GP exhaust
Racoon racing harness (Best harness out there. Never had a problem with the gy6 because of this!)
SS Brake line
GY6 throttle cable
GY6 rear drum brake pad
LED turn signals
LED Headlight (Super bright?as bright as the HID?s on my car)
Custom stealth LED tail lights
42mm foam air filter
Keihin PE28 carb
Push button start
NGK 7544 iridium plug
Custom rear license plate bracket
Composimo intake manifold riser
gy6 short axle
Composimo clocking flange
A9 cam
Yellow clutch spring
Yellow contra spring
Tachometer
List Date: 11/11/2016
For more info, click here to view the original listing: 160cc Big bore Custom Honda Ruckus
This item is no longer available.
