Results 1 to 6 of 6
Thread: Trans swap
    Jul 05 2015
    Trans swap
    Hi, so I have a 2007 b7 s4 drivetrain laying around (axles, driveshaft, diffs, trans) I like the smoothness of the s4 trans shifting compared to my 2006 b7 a4. Would the s4 drivetrain be direct swap for my 2.0t?
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    You can make it work if you swap it all out, but the reason why the other is smoother is the S4 has more power so it doesn't have to work as hard so it is smoother. Same thing happens when customer try the 2.0T and the 3.0T in the same car back to back. It wouldn't change much, but might have lower gears so car wouldn't be as fast.
    Jul 05 2015
    Quote Originally Posted by IVRINGS View Post
    I plan on going big turbo, and I was thinking of I would benefit at all from doing this swap when, I go big turbo
    Feb 16 2015
    Quote Originally Posted by sliceandkick View Post
    Pretty sure the ratios will be pretty shitty for a turbo engine
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Jul 05 2015
    Quote Originally Posted by gonemtbiking View Post
    Interesting thanks, the drive shaft and exiles wouldn't work with the a4 trans would it? I just have these laying around and find out if I could use it at all
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    I feel like this shouldn't be in the classifieds
    Sent from my Pixel using Audizine mobile app
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
