Results 1 to 31 of 31
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Car seat recommendations for S4
    I'm wondering what everyone is using as a car seat in their S4. I know previous threads have talked about the Recaro Performance Booster which is front facing 1 year + only. I need rear facing for now and would like it to last as long as possible for my 8 month old.
    I got the Graco 4ever and while it's decent, I do lose some room for the two front seats. Anyone have any recommendations for a long lasting, low profile, and preferably sporty looking child seat?
    Thanks.
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
    Aug 03 2013
    Renton, wa
    I run a graco mysize 65 for my 3 year old. It does rear facing as well as forward facing. He's had it since he was probably 18 months. Sadly there's not a ton of room in the rear seats so you will likely have space issues no matter the seat but he can fit in the seat comfortably forward facing and I can sit in the driver seat comfortably.
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Nov 10 2014
    Apex, NC
    personally i use Chicco Zipfit 30 but tons of threads on this http://www.audizine.com/forum/search...archid=7126714
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Quote Originally Posted by doug97gxe View Post
    Yeah I've seen them before but I'm out of town at the moment and my search on mobile keeps saying no results found. Even to your link.
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    I have two that work and two that don't.. I'll try to remember to post up the brands of both later this evening.. The ones we have in my wifes car - I think they are Boulevard don't even come close to fitting.
    '18 S5 - BBS / EPL
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by adamkb26 View Post
    my chicco zip fit works perfectly .. even now my son is 35 inches at 21 months he still some what fits.. unfortunately he is too young to go front facing but too tall for the 30 .. 30 means 30 inches 30 pounds.. he is still safe though because he is 25 lbs
    Present:
    Dec 07 2014
    Mn
    We just got the peg perego atmosphere infant. Haven't used it yet, but test fit just fine. Gotta slide the passenger seat up a bit but not to bad.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Get a convertible car seat.
    The Britax ClickTight Boulevard is great and worked well in the S4, but it is bulky. We have used it from the day we brought our son home from the hospital, to now at ~18 months.
    The Safety 1st Guide 65 fits rear facing in the 911 and made for compact cars, so it is definitely "low profile".
    Britax > Safety 1st, unless you are on a tight budget and/or have a small car. The Britax is built like a tank, and the ClickTight feature is awesome. I would call the Safety 1st "adequate".
    In case you did not know: You can go to Babies 'R Us to test fit car seats.
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    I have a Diono Radian. You can put it in the middle and still fit smaller adults in the left and right back seats.
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    I have the Evenflo Symphony Platinum or whatever it is, fit fine behind the passenger seat (rear facing). Still decent room in the front. My son is only one and getting him in and out is getting harder and harder as he grows. I put the seat behind the passenger seat to use the UAS hooks, so much easier.
    Im sure once we switch it to front facing it will allow for more room, which is "recommended" not till 2. Doubt that will work in the S4, maybe the wives Rav4
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by SDV325 View Post
    front facing will fit better than rear facing.. at least i hope so
    Present:
    Junior Member Two Rings The_Kracken's Avatar
    Sep 29 2016
    2015 S3; 2012 Q5 ; 1997 Chevy Tahoe
    San Jose, CA
    Quote Originally Posted by Victor Newman View Post
    I had two Dione Radians in my B7 A4 no issue. Front facing on right, rear facing in middle. I now have those seats in a 8V S3. Have to roll the front seats a little forward, but fits. For rear facing Diono sells a foam "riser" which allows from t seats to go back a little further
    Sent from my XT1096 using Audizine mobile app
    Jan 20 2014
    Calgary, AB
    Definitely will. Was just stating the the Evenflo model can be fitted in the rear facing position and allow for decent room upfront as well.
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Thanks for all the input. Almost everyone uses something different so I guess lots of good options. Something behind the passenger seat is definitely appealing instead of the middle.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    I suggest finding a baby store that will let you fit the seat in the car. I have used quite a few different seats for the kids. I have used recaro convertibles in the past, but the new models are getting much larger, so probably won't fit well in the s4 as a rear facing.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Senior Member Two Rings Dragoncub's Avatar
    Oct 07 2014
    New York
    My son just turned 9 months old today and he too has out grown this infant car seat, which had a 30" height limit. He used the Cybex Aton Q as an infant seat, I highly recommend this to anyone looking for an infant, no fitment issues. Highly regarded in terms of safety, you can check the independent crash test results online.
    cybex-online.com/us/carseats/atonq.html
    (some one earlier in the thread mentions that their child is 25 lbs and still can use their infant seat, I believe that is a misstatement, unless I misread the post. Usually the height/weight limit is either or, that is the way it is for the seat my son uses. You can use the seat up until the child either reaches 30 inches or 30 lbs, or whatever the limit is. So once either limit is reached, you must discontinue use of the seat.)
    As of the OP's questions, since my son has outgrown his infant see, I have ordered the Clek Fllo for him. http://clekinc.com/fllo (Their Foonf model is awesome as well)
    This car seat allows the child to be rear facing for a long time past the recommened 2 years of age. Remember that the safest position for any child in a car is rear facing, the longer you keep them rear faceing the better. I plan to keep my son rear facing well past age 2, some parents go up to 5 years old or older.
    Again, this is one of the safest car seats for a child, I am a very safety oriented parent. Note that all seat must meet minimum government standards in order to allowed into the market, but there are some seats that just go way beyond those minimum and this is one of them. I haven't test fitted this seat in the S4 but I don't think it will be an issue, this is a pretty compact seat, you can fit 3 across in a sedan. And I don't mind giving up a couple of inches in leg room if it means I will have comprise the safety of my son. My balls can stick to my butt checks for a little bit on the drive. Honestly, I don't think a couple of inches makes that much of a difference.
    I feel that the Clek Foonf and Fllo are the safest seats on the market (I'll let you do your own research on this), and the only reason I didn't get the Foonf is because of the weight. We are only getting one seat for now and didn't want to have to lug around a heavy seat between cars. Both these seat have crumple zones, so if you ever get in an accident, the seat will drop and absorb the impact, awesome technology for a car seat.
    This is my opinion on car seats, some of you my have different thoughts but this is how i feel.
    btw, the seats I mentions are a little on the pricey side, not sure what your budget it.
    Veteran Member Three Rings sferraro's Avatar
    Jul 19 2011
    2023 RS6 | 2018 Q7
    Golden, CO
    We just switched from an infant car seat to a convertible car seat in our B8 avant and we went with a Clek Fllo. They're not bulky at all (clean, minimal lines) and have a narrow profile like Diono car seats so you can fit three across. But you're going to lose front seat legroom no matter what car seat you select, specifically when installed rear-facing.
    2023 RS6
    CETE | color-matched rear caliper plates
    SOLD
    2013 allroad
    2011 A4 Avant
    Nov 27 2007
    Jersey City, NJ
    Resurrecting this thread... does anyone happen to know if it is possible to fit 2 car seats NEXT to each other in the back? ie:
    britax clicktight in one of the outward positions (directly behind passenger or driver)
    chicco keyfit 30 in the middle
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    I’ve had the diono radian for my daughter for the year I’ve had the car and it fits great. Two of them should fit in the back (forward facing). It’s very slim so it has the room. You could use it in a spot for forward facing for sure with another brand in the other spot. Pretty sure there won’t be much leg room for the driver no matter what seat is behind you though.
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Ha, thought this was the thread in the TT forum when the notification popped up, but same advice with the diono will work with the S4 for sure.
    Nov 27 2007
    Jersey City, NJ
    thanks! both are going to be rear facing for at least another year, i'm looking at options that will prevent me from having to trade in the S4 :/
    Veteran Member Four Rings Hightekflytech's Avatar
    Sep 24 2013
    I.E. Cali
    For the people that have the convertible seats, is there an issue with your kid(s) slumped over when they're sleep? That has been my main issue with the Recaro convertible seat that I have
    Established Member Two Rings NICOOOOS4's Avatar
    May 05 2018
    Acura RDX
    Bay Area CA
    diono radian rxt ( with angle adjuster foam bottom -purchased separately) i have 2. 1 for my rear facing baby and one forward facing for my other kid. for rear facing its kinda tall the back rear so it hits the front seat and front seat needs to be pushed a little forward. my wife who sits there is 5’3 and feels fine. i also feel fine sitting front passenger at 5’6. i’ll take pics in a bit
    May 05 2018
    Acura RDX
    Bay Area CA
    IMG_1953.JPGIMG_1955.JPGIMG_1956.JPG last pic to show how close seat has to move
    Veteran Member Three Rings street2gen's Avatar
    Oct 13 2013
    Whitewater, WI
    Quote Originally Posted by NICOOOOS4 View Post
    We have a britax boulevard clicktight and i think it is very similar to that diono. Will have to put it in the s4 as its in my wifes alltrack to compare.
    Mar 09 2014
    Got a Maxi-Cosi Pria 85 max on the way, will update with fitment, but pics and reviews look great
    Best Price i've seen here:
    https://www.albeebaby.com/maxi-cosi-...gle-black.html
    Veteran Member Three Rings Spoorguy's Avatar
    Mar 26 2015
    Rheinland Pfalz, Germany
    I second this Diono RXT. I have a rear facing child, usually put them on the passenger side and same issue with having to put seat forward, if I have to, I do put him in the middle and get pretty good clearance for both passenger and driver. Little snug but I got it due to ratings and the fact that it’s slimmer then some. It’s a heavy guy but well worth it. Great company as well.
    2002 B5 S4 (Sedan), GIAC stage 1, vinyl wrapped dark gloss grey - SOLD
    2010 B8 S4 Unitronic DP | AWE Tuning- Touring w/ Non Res DPs | Merc Racing HX | Airlift 3P - SOLD
    May 05 2018
    Acura RDX
    Bay Area CA
    Quote Originally Posted by Spoorguy View Post
    agreed i got them due to the ratings and build construction. very solid car seat and if u decide to travel by plane with them they fold too. they can be pricey but i think it’s worth it. we have 4 of them (2 in each car)
    i think they’re on sale right now too
    Mar 26 2015
    Oh yes forgot to mention, great for strapping into the plane when traveling. Only thing to keep in mind is seat space on different airlines. Some airlines aren’t as spacious and so you’ll have to forward face whereas some have enough space for rearward facing. Can get a carrying strap, bag and other little things to make it more travel friendly. Overall solid seat that’s suppose to last you many years beyond initial purchase
    Established Member Two Rings davep411's Avatar
    Jul 19 2014
    washington
    I know this is an old thread, but for people who actually use search and are wanting to know, thought I would show how my seat fits with a 2.5yo in the seat! Seat is Diono radian rxt. Front seat is all the way forward with the the back slightly reclined. He can put his feet on the back, as well as reach the center vents with them.
    Sent from my SM-G950U using Tapatalk
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 03 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Radians are great.
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
