SOLD
I can't sign in to my vortex account for some reason so I'll post here too! I want this gone so I don't have to store it again. Turn key. Zero issues...I can't stress that enough.
Link to photos of most recent updates
https://flic.kr/s/aHsjEWQg6D
Some recent ones:
Pics as of 5.22.17
The basics:
1997 Audi A4 1.8T Sport (2871R tuned by AST)
Aluminum Silver
Quattro
Manual (5 speed)
275,xxxkms
Oil changes with Motul full syn. every 5000-7500kms
Rust sprayed with Krown since I've owned it
I am technically the 3rd owner. The first was Audi as this vehicle was a demo until it was purchased by the gentleman I bought it from. I purchased it in December, 2006 with 115,000kms on it.
Modifications:
All in chronological order.
Engine/Trans:
-3" ATP testpipe with CEL prevention-June 07 @ 127,000kms
-eBay short shifter (B&M clone)-December 07 @ 143,000kms
-034 Stage II turbo setup-June 2012 @ 208,000kms:
GT2871R eliminator
Genesis 415cc injectors
Eurodyne Maestro ME5
VR6 OBDII MAF (3")
Hallman Pro MBC
-3bar FPR-September 2010 @ 211,000kms
-034 in line fuel pressure gauge-October 2010 @ 215,000kms
-Forge 004 BOV-December 2010 @ 219,000kms
-AEM dryflow cone filter-April 2011 @ 226,000kms
-Wrinkle black IM/coolant hard pipe-May 2011 @ 229,000kms
-Facelift (clear) coolant expansion tank-May 2011 @ 229,000kms
-Facelift cowl cover and raintray-June 2011 @ 229,000kms
-3" turbo back exhaust, stainless, custom, with Magnaflow muffler-July 2011 @ 233,000kms
-Saikou Michi custom catch can/-AN fittings-February 2012 @ 242,000kms
-Euro B5 Passat engine bay cover-February 2012 @ 242,000kms
-034 ICM delete/2.0FSI coil pack upgrade/brackets/coil packs-March 2012 @ 242.000kms
-Derale power steering cooler (stock SMIC location)-March 2012 @ 242,000kms
-Southbend stage III clutch/pressure plate/re-machined OEM flywheel-March 2012 @ 243,000kms
-Franken turbo high flow exhaust manifold-April 2013 @ 258,000kms
-A/C delete-April 2013 @ 258,000kms
-Treadstone intercooler and custom charge piping-April 2013 @ 258,000kms
-MAF replaced, MAF wiring re routed and custom intake-April 2013 @258,000kms
-Saikou Michi custom catch can (valve cover vented)-May 2014 @ 267,000kms
-991 coolant and oil caps-May 2014 @ 267,000kms
-Gruvenparts billet oil dipstick-May 2014 @ 267,000kms
Suspension/Drivetrain:
-Stern poly-urethane rear diff carrier mounts-May 09 @ 182,000kms
-034 track density front strut mounts-May 09 @ 182,000kms
-ST coilovers (first rendition)-May 09 @ 182,000kms
-JHM delrin shift bushings-July 09 @ 186,000kms
-Neuspeed adjustable rear sway bar (19mm)-July 09 @ 186,000kms
-Poly-urethane rear sway bar bushings with subframe mounts-July 09 @ 186,000kms
-TRW rear sway bar end links-July 09 @ 186,000kms
-Stern solid rear diff. mount (power ring)-October 09 @ 191,000kms
-Center driveshaft CVs replaced, 034 hanger bearing-April 2012 @ 244,000kms
-Stern motor and tranny mounts-May 2012 @245,000kms
Brakes:
-986 Porsche Boxster front Brembo calipers, D2 A8 rotors, custom brackets and lines-August 2012 @ 252,000kms
-B6/7 S4 rear rotors, B5 S4 rear calipers, custom lines and 034 brackets-July 2013 @ 261,000kms
Exterior:
-New front fenders/shaved Audi logo/sidemarkers-June 2010 @ 208,000kms
-DEPO e codes and DDM 55w 6000k bulbs-May 2013 @ 258,000kms
-Euro (96 A4) trunk lid-Sept 2013 @ 258,000kms
-B5 RS4 front grille-April 2013 @ 258,000kms
-B5 RS4 side view mirrors, brushed and anodized-April 2013 @ 258,000kms
-Facelift hood-June 2013 @ 259,000kms
-A-pillars, 14" of the hood, fenders, and 6" of the roof were covered with 3M clear vinyl
-S4 front bumper, side skirts, OEM hardware, rear valence-May 2014 @ 267,000kms
-Euro pre Facelift S4 tails-January 2014 @ 267,000kms
Interior:
-Redline Goods perforated black leather shift boot w/ grey stitching-December 2007 @ 144,000kms
-Superbright interior LED bulbs-April 2008 @ 154,000kms
-Audi Concert radio (from a 98 A4)-July 2008 @ 160,000kms
-Podi electronic stepper oil pressure gauge/42DD sender-November 2010 @ 216,000kms
-Sunroof console painted black-January 2011 @ 221,000kms
-S4 interior grab handles-January 2011 @ 221,000kms
-Black S4 sun visors-March 2011 @ 225,000kms
-DICE electronics iPod connector-September 2011 @ 236,000kms
-Podi electronic stepper boost gauge-January 2012 @ 242,000kms
-S4 centre console (armrest portion)-June 2012 @ 245,000kms
-Custom air leather steering wheel-August 2012 @ 252,000kms
-Recaro leather sport seats, sliders and custom brackets-May 2013 @ 258,000kms
-Custom perforated leather wrapped e brake lever-April 2013 @ 258,000kms
-B5 RS4 interior door pulls-April 2013 @ 258,000kms
-Custom wrapped A and C pillars, pre Facelift Euro S4 B pillars-April 2013 @ 258,000kms
-RS4 shift knob and e brake levers-July 2013 @ 261,000kms
-Custom black headliner-May 2014 @ 267,000kms
-Custom diamond stitched door cards, piano black vinyl belt line trim, 99.5 centre console-April 2014 @ 267,000kms
Maintenance:
-Right outer CV boot-January 2005 @ 100,000kms
-Right rear wheel bearing-January 2005 @ 100,000kms
-Left driveshaft-January 2005 @ 100,000kms
-Left rear CV joint/ABS ring-November 2006
-Left front lower link arm-November 2006
-Left rear lower link-November 2006
-Right motor mount-March 2007 @ 122,150kms
-Oil cooler seal-March 2007 @ 122,150kms
-Gear oil changed-May 2007 @ 126,000kms
-Rear diff. seals-July 2007 @ 131,000kms
-HVAC control module-February 2008 @ 146,000kms
-Tail light bulbs replaced-March 2008 @ 150,000kms
-Right rear wheel bearing-March 2008 @ 152,000kms
-Left rear brake caliper-September 2008 @ 165,000kms
-Coolant temp. sender-November 2008 @ 171,000kms
-Right rear wheel bearing-March 2009 @ 178,000kms
-Left front outer CV boot-March 2009 @ 178,000kms
-Cabin filter-March 2009 @ 178,000kms
-Rear diff. seals-April 2009 @ 181,000kms
-TRW rear brake rotors/Mintex Red Box pads-April 2009 @ 182,000kms
-Right rear caliper slider boots-April 2009 @ 182,000kms
-Right rear brake caliper-May 2009 @ 183,000kms
-ECS headlight repair tabs (pass. side)-July 2009 @ 186,000kms
-ECS Ultimate timing belt kit: July 2009 @ 186,000kms-
Thermostat
A/C drive belt
Timing belt kit/tensioner/roller/idler roller
Power steering belt
Alternator belt
Water pump/bolts
Timing belt roller
-Fuel filter-October 2009 @ 192,000kms
-Water flange/O-ring/bolts-May 2010 @ 208,000kms
-New windshield-June 2010 @ 208,000kms
-Secondary washer fluid reservoir delete-October 2012 @ 215,000kms
-Oil dipstick shroud replaced/painted wrinkle black-November 2010 @ 217,000kms
-Valve cover gasket/Variable valve timing tensioner gasket-February 2011 @ 223,000kms
-PCV breather hose fitting/valve-March 2011 @ 223,000kms
-Power steering cap, washer fluid cap, coolant tank cap replaced-May 2011 @ 228,000kms
-Wagner thermo-quiet front brake pads-June 2011 @ 230,000kms
-Upper/lower rad hoses/clamps-October 2011 @ 241,000kms
-Compressor housing>FMIC 30* silicone elbow-March 2012 @ 242,000kms
-FMIC support brackets re-done-March 2012 @ 242,000kms
-Flywheel bolts, pressure plate bolts, ball pivot pin, intermediate piece, retaining spring, clutch release lever, release bearing-March 2012 @ 243,000kms
-Turbo>Downpipe gasket-March 2012 @ 243,000kms
-Turbo coolant feed line washers replaced-March 2012 @ 243,000kms
-All front control arms/end links/tie rods (inner/outer) replaced-April 2012 @ 244,000kms
-Left front outer CV boot replaced-April 2012 @ 244,000kms
-Front and rear center driveshaft CVs replaced-April 2012 @ 244,000kms
-Coolant temp sensor-May 2013 @258,000kms
-Front left Inner CV boot-June 2013 @ 259,000kms
-Upstream O2 sensor replaced Bosch-July 2013 @ 260,000kms
-New OEM battery/tray/cabin filter-May 2014 @ 267,000kms
-New Bosch starter-June 2015 @ 271,000kms
-New OEM wiper arms-June 2015 @ 272,000kms
Obviously, a LOT of time and money has been spent to ensure this car has been maintained over the years. I feel like I have created a very good balance between style, looks, and performance; all while retaining many, if not all of the creature comforts that this vehicle came with from the factory.
I have every single reciept, price, everything for this vehicle...even the things that were done before I bought it.
The car currently has 18x8/9 BBS LMs on it, with 215/40 Falken FK452s all around. They have machined faces and raw windows, with clear top coat.
Here is my build thread:
http://forums.vwvortex.com/showthrea...k-grab-a-drink.
Here is my flickr set of the car's progress:
http://www.flickr.com/photos/geoff16...7623167376246/
I will get more pictures up ASAP. For now I wanted to get the ball rolling.
I have well over $25,000 into this vehicle on top of the purchase price and that is having done 95% of the work myself. There is sentimental value and I appreciate the fact that this does not transfer to a new owner but I will price it at what I feel it's worth. If you would like to buy a less expensive car and modify it as such, you are free to do so.
Will include any spare parts the new owner may want, including S4 door sills which are near impossible to come by (1 side is new 1 is used). I have a lot of spare parts...
So, that being said:
Price (as is with valid e test as of July ):
$9,500 (includes dongle for Maestro tuning suite)
$7,000 bring your own wheels!
I absolutely will NOT part this vehicle out. If it does not sell I will keep it and continue to sink money into it.
If you have ANY questions please feel free to ask. My name is Geoff, 905-409-7606
Sent from my SM-G930W8 using Tapatalk
