Results 1 to 10 of 10
    Apr 11 2012
    2008 VW R32 Audi TT 225 mk1 audi B7 A4 1999 Jeep Xj B6 a4
    Corning NY
    removed stock turbo to replace coolant line what are the steps to prep the turbo when
    turning on the car. I took some fresh oil and dumped in turbo oil side. anything else?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by rfelker View Post
    Use you oil pump can to also pre-fill the turbo oil supply line and you should be good to go.
    And if you haven't hooked up the boost hose yet you can use your fingers to spin the turbo while you add oil to the oil port.
    Jan 06 2009
    Also, disconnect the fuel injector harnesses and crank the engine over to prime everything.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Apr 11 2012
    Corning NY
    I used a small turkey baster. is that enough oil? hahahaha
    I didn't spin the turbo though.
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Just fire it up. It's not going to start spinning until the exhaust gasses get hot and there is sufficient flow anyway. At that point the engine is running so oil will be flowing. If not then turbo problems are the least of your problems.
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    ^^^^ lol. The turbo starts spinning as soon as the exhaust gasses start moving.
    Apr 11 2012
    Corning NY
    It says that turbo spins when starting engine from BW pdf. So did what it said in the pdf. Oil in the turbo. unplugged fuel injector harness and rolled it over. Plugged everything in and started car 200 miles later everything is fine
    Jan 06 2009
    These little turbos definitely spin at idle.
    B7 2.0t
    Jan 31 2015
    Boise Id
    Starter cranks the engine at ~300 rpm. Until the engine fires up there are no exhaust gasses. There is a bit of flow through the exhaust manifold but there is no heat or significant pressure behind it. There is absolutely no way you are going to damage a turbo by starting the engine it's attached to no matter how dry it was when you installed it, as long as the engine it's placed on has good oil flow.
    Nov 10 2015
    Sudbury, ON
    I unplug coil packs, and crank it over for like 15 seconds. then plug it back in, and go
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
