http://www.audizine.com/forum/showth...Boost-problems
So far I have:
- Replaced DV
- Replaced N80
- Replaced PCV
Installed a Cheap boost gauge just to see if there is any boost (the gauge is working good)
Today I tested N75 disconnecting it from the wastegate to see if there is some boost and the result is 2psi. when in idle the gauge is in 7 below zero.... the most I got even with the wastegate disconnected is 2psi
What should I do next??? is my turbo dead???
Any help will be really appreciated
Thanks in advance
