Results 1 to 11 of 11
    Apr 19 2014
    Mello
    2004 Audi a4 parts car
    Hello All I have a 2002 audi a4 3.0l 6 speed manual tranny that needs an alternator and some misc parts. Can I buy a 2004 audi a4 1.8l turbo for parts. The main parts I am looking for is the alternator ac compressor and condenser and window switches and other little parts. Will these parts be compatible. Any help would be greatly appreciated I need to buy the car quick because the price is right.
    Jul 14 2009
    Pasadena
    the parts u listed may not be compatible. whoops glossed over 1.8 and 3.0
    - - - Updated - - -
    i have my front driver window switch setup if u need one. its mint i took it off after 5k usage.
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    The AC compressor will likely be different. I'd also check the alternator as I believe the 1.8T came with 2 different rated versions, one was the same as the 3.0, the other had a lower amp rating.
    Sent from my Pixel XL
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Alternator on 1.8 and 3.0 are completely different.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    How much is the car?
    -Tim
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    Quote Originally Posted by imnuts View Post
    the bracket yes, but the compressor is the same
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Apr 19 2014
    Mello
    $800
    - - - Updated - - -
    800
    Jun 26 2015
    Tampa, FL
    Go to ecstuning.com, put in your car, and look up the part. It will tell you what cars the part fits.
    Aug 12 2009
    Dirty Jerz
    Quote Originally Posted by blitz2190 View Post
    There are 2-3 different A/C compressors for the B6, and there is one VIN split in the 2003 model year. I pretty sure that there is a thread around here that explains the differences, and it is more than just the bracket, there are threaded fittings that are different as well.
    Jan 09 2012
    MA
    go here
    http://www.oemepc.com/audi/main_grou...e_standart/249
    Plug in both VIN's and compare part numbers.
    Jul 31 2014
    NH
    just going from personal experience and that most parts fiche list the same one for both, the one from 02 3.0 fit on my 03 1.8t, if they are different I didn't notice, but can't speak for the 04 verison
