Was wondering if anyone had any experience with the PCV valve on a 4.2. My s4 has always had oil consumption problems but latly it is getting really bad. When I first got the car it was about a quart ever 500-600k. now its way worse. after moths of owning the car the PCV valve was making a weird noise. I was able to prop it and tighten it to make it stop but im reading now that the PCV valve can actually cause oil consumption. I know I probably shouldn't have propped it to fix it but now im starting to slightly hear it again. wondering if its getting worse which is causing more oil consumption. I always thought it was due to bad valve seals but im wondering otherwise. Any thoughts???
