Results 1 to 40 of 48
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Question Cold start issue still continues...
    Still trying to figure out my cold start issue.. Does anyone have any ideas? My set up is in my Signature.
    Symptoms:
    - It will take a long crank or rough start before startup in the AM after a night of sitting. Sometimes it will take two cranks.
    - After going into a store or the gym and than back out, it will start up easier or normal.
    - My vacuum (-16) and idle (1.4k) is normally high on cold start ups than goes down when more warm, 19 Vacuum, 800k rpm. (I think its normal for tuned cars to start high on cold start?)
    - Also randomly in idle (not normally) the vacuum will go up as well as the idle, but i just tap the pedal and it'll go back to normal.
    - I boost to about 18-20psi, tune calls for 22psi~. (I have a MBC I'm running that I set to that)
    - I also have an exhaust leak between my EM and my turbo. I have to change that gasket out still, somehow it blew out? (no idea) But it does make a rattle noise up front on cold start, not sure if that is affecting my cold start issue as well. I plan on fixing it in the next week or so.
    What i've changed so far:
    - Walbro Fuel Pump 255lph
    - New Fuel Filter
    - New MAF housing & Sensor
    - New 630CC Ringer racing injectors
    - ECS 2.0 coil conversion, ICM Delete
    - New Interstate battery
    - OEM CTS
    I feel like I changed everything already but it still continues. Is there anywhere I should look? Or is this a normal thing with tuned cars having rough cold starts? Other than that, my car drives great.
    My Daily
    1999.0 A4 1.8TQM AEB Casa Blanca White
    Stage 3 United Motorsports - Vogtland GT3 - Frankenturbo F21L - TR18T FMIC - 630cc - 3" MAF - 3" 034 HFC - 2.5-3" Neuspeed Catback - ECS RA4 Clutch/12lbsteel - OEM Roof Rack - K&N/F21 TIP - DAWES MBC - VDO Gauge - TurboXS DV - 034 PCV - 034 Rear Sway/Subframe - 034 ICM Delete 2.0 coils - Stock Internals
    Active Member Two Rings Karlo's Avatar
    Aug 28 2016
    Croatia, Europe
    Dirty throttle body?
    Sent from my LG-H815 using Tapatalk
    Audi A4 B5 1.8T Quattro With custom exhaust
    Active Member Two Rings kjames1270's Avatar
    May 16 2016
    New Jersey
    I'm having similar issues. The check valve idea right after the fuel pump was done by Seerlah, a member here. Gonna give it a try
    http://www.bmwe34.net/E34main/Trouble/535ihot_start.htm
    Sent from my A0001 using Tapatalk
    Feb 27 2011
    Winnipeg
    Being aeb it could be the beginnings of the failure of your throttle body, mine I tried adapting and it failed saying could not adapt. Ended up getting a used replacement and adapting it.
    Dec 13 2015
    PNW
    Quote Originally Posted by seanf86 View Post
    I forgot to mention that I just got a different throttle body from another car and manually adapted it, because I was having "fault in basic settings" issues of adapting before. Not throwing any codes now after erasing the codes in vagcom.
    My Daily
    Dec 13 2015
    PNW
    Quote Originally Posted by kjames1270 View Post
    We have a check valve in the fuel pump lines?
    My Daily
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by PsorianoPre99A4 View Post
    It's in the pump I believe
    Sent from my XT1058 using Tapatalk
    Dec 13 2015
    PNW
    I just replaced the entire pump and and basket with a walbro.
    My Daily
    Feb 27 2011
    Winnipeg
    It may not have a built in check valve that I don't know.
    Another thought since you've done CTS and a throttle body is the crank sensor, usually they fail when hot but ohm it out when cold, the fuel pump doesn't start pumping until it sees cranking, if the sensor is failing it could be the problem. I don't know the specs of it but it's in a Bentley manual and possibly online.
    Dec 13 2015
    PNW
    The PO changed the CPS about 40k ago & there isn't a code for it. This is just a sign of it slowly dying? How often do they go?
    My Daily
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    In my case, aftermarket tunes did not prime my pump. Put a stock computer in, primes, aftermarket, no prime. This is for Unitronic and Maestro, dont remember if it did on older tunes as well. Can you hear the pump prime?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 13 2015
    PNW
    Quote Originally Posted by Avant Nate View Post
    Yup I definitely hear the pump prime.
    - - - Updated - - -
    I've also heard thats the case for aftermarket tunes. But i'm not sure.
    My Daily
    Nov 03 2011
    All Over!
    I would be looking at fuel rail hold pressure. Unlike the B6 1.8T, the AEB in the B5 has a return. Check the fuel pressure regulator. Pull off the vacuum line, and try sucking from the diaphragm end. A torn diaphragm will meet with little or no resistance. If there's any gas residue in the vacuum line, or any gas dribbles out, it's shot, and should be replaced.
    The internal spring could also be bad, this will allow the pressure in the rail to drop, and the fuel to drain back to the tank after shut down. The fuel pump only primes so much upon starting, it will not give max pressure to an empty rail.
    Try this after the car has been stood overnight:
    Turn the ignition on, then off, a few times, making sure the fuel pump primes each time. It should get to the point you wouldn't hear the pump much, as the rail pressurises. Then try starting the engine. Does it start easier?
    You can also run the fuel pump constantly, before starting. This can be achieved by pulling the fuel pump relay, and applying a jumper cable to terminal 30 and 87a. Or open the relay, then manually close the contacts to activate the pump. Then try starting. If it starts as normal, then you've got a fuel pressure issue, which would point to a tired FPR.
    1986 Type 85 Audi 90 quattro
    Dec 13 2015
    PNW
    Thanks for the reply Nollywood. I pulled off the vacuum line and didn't notice anything drip. When you say "pull off the vacuum line, and suck from the diaphragm end" what do you mean by that?. I haven't yet bought a FPR because I want to make sure thats the issue, i've spent a bunch of money trying to chase this cold start issue. It always starts up right away on the second start. Any other ideas anyone??? I still have no codes.
    My Daily
    Active Member Two Rings WyGuy1.8T's Avatar
    Oct 01 2012
    Built B5.5 passat, 92 Corrado SLC
    Pittburgh, Pennsylvania
    Just a thought, maybe you don't have enough cranking fueling in your tune? Did you have the problem prior to having it tuned?
    Dec 13 2015
    PNW
    It wasn't as bad I suppose, but than again this could be an overtime kind of thing. Just wanting to know where else to look? Wondering if I should re Gap plugs. Since I got bigger coils
    My Daily
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    My 97 had a problem like this and it ended up being low compression.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Dec 13 2015
    PNW
    What would cause low compression?
    My Daily
    Oct 01 2012
    Over time your piston rings wear down from friction on the cylinder walls, so you don't have a good seal in the cylinder. Your valve seats can also not seal on the cylinder head as well as they did from the factory, which has the same effect.
    And as far as the bigger coils go, if your plugs are gapped at .028, you're fine. There is some controversy on whether or not running a larger gaps on plugs with the 2.0 coils gives you more power, some people had different dyno results, different theories, etc.
    Dec 13 2015
    PNW
    What signs of drivability would lead to low compression?
    My car drives hard and boost right away. No codes. Is there any other signs that would point to low compression? The car is old, but there is only 138mi on the motor, and it's been treated well it's life.
    My Daily
    Oct 09 2012
    Well do a compression test and find out the health of the engine. My car lost compression on cyl one and it took longer and longer to start up untill it just wouldn't anymore. Piston rings where bad.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 13 2015
    PNW
    Ok is it pretty simple to do with these cars? Is there any other areas I could check instead of compression, I feel like it can't be if my idle is generally good and no issues really other than a slower cold start. It also isn't consistent.
    My Daily
    Oct 09 2012
    Yep Just do the compression test. Nothing else easier to check. From what you are describing and my past experience it is worn piston rings. 100PSI is the rebuild limit and 43PSI difference between cylinders is also NFG.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 13 2015
    PNW
    Quote Originally Posted by King_ View Post
    Whats NFG? I don't have the tool to do the compression test. I'll have to ask around or just take it in. However, I was thinking I could also try the fuel pump relay or the CPS. I just changed the fuel regulator and set my DV splitter to recirculation.
    My Daily
    Oct 09 2012
    no fucking good.... hurry up and do a compression test... like your in the states. go to horrible freight and get one. http://www.harborfreight.com/compres...-pc-62638.html
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 13 2015
    PNW
    Ok what should the psi range be for each cylinder? And if I have low compression on one of the cylinders am I screwed? How long did this persist for you when it happened to you?
    My Daily
    Oct 09 2012
    rebuild limit is 100psi and the maximum psi difference between cylinders is 43psi. so above 100 and within 43 of eachother. the car fires on cylinder one so that is the one that sounds like its low compression. I had the issue for probably the whole ownership. 265kms-311kms which it died at with 50~psi on cyl 1.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 13 2015
    PNW
    Ok Cylinder one is the closet to the T belt right? My car is only at 138k (222 kms). It is still inconsistent. I will update once i do a compression check. Thanks King.
    My Daily
    Jul 27 2011
    IN
    Could be a failing crank shaft sensor, you can check the resistance between its pins to confirm it falls in the spec.
    Dec 13 2015
    PNW
    Quote Originally Posted by woolveren View Post
    My cousin was saying this too. It has been changed already once in the car about 50k ago. How do I check the resistance between its pins? Do I have to take it off first?
    My Daily
    Dec 13 2015
    PNW
    Update Post:
    Changed the Crank Position Sensor and Fuel Pressure Regulator still having the cold long start issue approximately 4-6 seconds now. Three seconds when sitting for a few hours. In consistent honestly. Sometimes it starts after 1-2 seconds (normal?) Idk what the issue is. My car boosts to 22psi and drives great. Vacuum generally stays around 18-20hg, idle always at 800. I took it to a known tech locally and he said to recheck the fuel line that connects to the pump when I replaced it, mentioning the screw clamps don't hold a good seal on the accordion looking hose that normally goes with the OEM pump. He said I should switch to actual fuel rubber hose when I did the fuel pump, will do that next and recheck work. Everything else checks out, air/fuel/spark wise. Also haven't replaced the fuel pump relay, but I don't have codes so I didn't try. Any other suggestions from here would be helpful...stumped.
    My Daily
    Oct 09 2012
    did you compression test like i said months ago? Doesn't sound like it. I literally changed everything on my aeb and the problem was low compression so fucking test it.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    Do this. I had an issue like that and it was a leaking headgasket as well as dirty valve seats (rebuilt my bottom end 15k miles before so I knew rings weren't bad). Compression test takes maybe 10 minutes. Just pull all your spark plugs out and put the tester in cylinder 1, crank for 8-10 seconds or until the pressure stops rising. Repeat in cylinders 2/3/4. Log the pressures and compare them.
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    Dec 13 2015
    PNW
    I highly doubt it's compression, had an experienced mechanic who owns multiple b5s say the same. Didn't do the test but I will, I have. I doubt in my mind compression will be fine.
    My Daily
    Dec 13 2015
    PNW
    Don't I do it one at a time? Not take all the plugs out? I have to source a gauge too.
    My Daily
    Oct 09 2012
    you take it out them all out so the crank spins freely. do the fucking test or stop asking for help.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jan 08 2012
    2015 VW GTI
    If you leave the others in and you have a leak between cylinders it wont be as noticeable. After doing the test with them all out, then if you so desire you can check for leakage between cylinders, but no point because you have to replace it anyways if its bad. So take all 4 out, then check compression on them one at a time.
    Harbor freight sells them for dirt cheap. Part stores will probably rent them out for free. Also, no offense to your friend but "experienced mechanics" are a dime a dozen on forums. I've seen a million times where people say a certified/professional mechanic did this or that and its wrong.
    Dec 13 2015
    PNW
    UPDATE:
    Did compression test, drove around, came back home after car was at operating temperature, ten minutes later, did test.
    Starting with the cylinder in the front of the car to the back of the motor 154, 154, 146, 130
    So would that be the cause of my cold start issue? I haven't replaced the fuel line in the pump yet, but any other ideas?
    My Daily
    Dec 13 2015
    PNW
    Bump..I'm thinking it's fuel related. Carbon build up? Any other suggestions to move forward? Are these numbers bad?
    My Daily
    Junior Member Two Rings
    Sep 05 2014
    Skagit WA
    Read a book... specifically a workshop manual. All the info your need is in there, wrote by the engineers that built your car. Or pay a professional to diagnose it.
