Results 1 to 3 of 3
    Jan 25 2012
    Mckinney, Tx
    Just bought a 2005 A6 4.2 with an engine issue
    I bought it for a decent price knowing it had an issue. The interior and exterior are in excellent condition for a 11 year old car. That's why I had to buy it and brought ng t back to life.
    I believe it might have a camshaft chain issue, just from lurking around here and watching some YouTube videos.
    I'll pick it up locally next Monday and trailer it home as I don't want to do anymore damage to her.
    My question to you guys is, once I do get her home, where should I start, should I do a compression test/leak down test?
    Of course if I had a vagcom Id use that.
    Go easy on me.
    Junior Member One Ring TechnoToad's Avatar
    Nov 16 2015
    2005 Mini Cooper S Convertible
    Springfield IL
    Hey congratulations on your new purchase....If you think you have a cam chain problem... The last thing you want to do is turn over the engine, with the starter....If the cams are out of time, there is a possibility of the valves could actually contact the top of the pistons. No good: I would pull the valve covers and spark plugs, and turn the engine over by hand..checking for any possible contact! If you do have chain problems....the engine is going to have come out...Good luck!
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    The 4.2 is known to have an issue with the chain guides and tensioners. In order to get to the guides and tensioners you need to either pull the engine out or drop the transmissions. I had it done on my old 4.2 when it had approximately 135k miles on the odometer. Dealer charged a little under $10,000. Good luck
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
