Results 1 to 6 of 6
    May 09 2015
    Carson City, Michigan
    Overheating question.
    So I'm looking at buying a 03 a4 with the 1.8t and it has a blown headgasket. The owner told me the car overheated and shut its self off. It that "normal" for these cars, for it to shut itself off? Or is it that he overheated it soo bad that the hard warped incredibly bad and the compression dropped to the point the car quit. He says the car has a dead battery but won't start even when he tried to jump it.
    Aug 19 2013
    minnesota
    Quote Originally Posted by Pgtzet3 View Post
    The motor seized up mechanically from being too hot. The question is why did it overheat? Either way you should expect to replace the motor.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    May 09 2015
    He said it rolls over so it's not seized. And I've done several 1.8t headgaskets. So back to the original question. Do these cars have a fail safe that shuts the car down if it starts to over heat?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Nope.
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    it either got hot enough to seize then cooled off allowing the the metal to contract and now spins again, or got hot enough that the head warped and lifted causing a head gasket failure, either way there is some damage somewhere. It was poor judgement on his part to run the car after it started heating and you may need an engine or a head.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Jan 28 2011
    1956 Pontiac Safari
    Nashville
    No fail safe. Unless he's practically giving you the car, I'd buy something else... I owned an 03 for 10+ years, just sold it for 2k (all I could get out of it) in perfect mechanical condition with fresh timing belt job, brand new tires, and a host of other goodies.
