Originally Posted by
merlinq21
You know you maybe on to something- I have been recently using 94 from petro can like the last 4 fill's before that I used three different shell stations - I wonder if the 30% ethanol is the issue. Going to run one more fill using Shell and see if that doesn't get me back some better results - good point and thanks
You're most welcome. It might not be the final solution, but it can't hurt.
The reason I found this out was this past summer I went to
www.techmax.ca checking to see if my engine needed to be de-carboned using the walnut shell blasting process since the FSI engines are noted for encountering performance issues due to carbon build-up on the intake valves and valve area. The owner there, Atilla, mentioned to me that they tested the PetroCan 94 octane to have nearly 30% ethanol additive. I've been using that Petrocan 94 and the previous Sunoco 94 for almost 15 years on my high HP TT 300ZX believing it had a much much lower ethanol content as they advertised only ~ 10%.
If your engine hasn't been de-carboned, then perhaps that may be why you're beginning to see mileage issues. There's plenty of threads on the subject. There are various de-carboning processes but the most effective and long lasting is the walnut shell blasting process. It's been a common practice for FSI engined BMW's for years and the process has just migrated to the VW/Audi FSI engines. Perhaps something to think about after your gas type change. Here's a good video on the subject. I thoroughly believe the Italian tune-up process is a good occasional practice.
I like this guy -
https://www.youtube.com/watch?v=RnhUJsZXzmg
