Results 1 to 9 of 9
Thread: Building engine
    Established Member Two Rings GottaBAUDI's Avatar
    Sep 01 2015
    Syracuse NY
    Building engine
    I live in ny. So where is a good reputable place to install rods and how much would it cost
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    I can't speak for NY but the machine work i had done to balance my assembly was about 450 and another 150 to inspect and hone the block, and it needs to be balanced, the theory of drop in rods is just ridiculous on any engine, when i got mine back they showed me that its was 2grams out on the whole assembly, this was with the newer rpm I-beams. if your looking at having the shop doing everything, plan on over $3000 if not more. At a minimum you should have the bearings replaced while everything is out, and new rings. with machine work(block checked and honed, balanced assembly) and all the parts, I spent $2500 but I put the engine together myself. If you set on doing it call around to a few shops that work on audis and ask them for recommendations, and then talk to the machine shops you find and see what there experience is with the 2.7.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Sep 01 2015
    Syracuse NY
    At that price might as well rebuild the engine
    Sent from my SM-G935V using Tapatalk
    Jul 31 2014
    NH
    I did, I replaced every bearing and thrust bearing, all new oem rings, and the rpm rods with arp studs. you also have to factor in things like rear main and crank seal, and all the little things, as well as a timing and headgasket kit.
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    We can certainly help you with that we are currently building two Tial 770 cars and know this platform quite well.
    Thanks,
    Alex.
    Sep 01 2015
    Syracuse NY
    Ahhh i see
    Jul 31 2014
    NH
    Quote Originally Posted by Excelerate Rep View Post
    Thanks,
    Alex.
    beautiful engine but I think Syracuse is about 5 hours from there haha. I spend a good amount of time out there and its a hike to anywhere.
    Sep 01 2015
    Syracuse NY
    I don't mind traveling though because getting this engine built would be worth it.
    Jul 31 2014
    NH
    Quote Originally Posted by GottaBAUDI View Post
    call them up then, like I said call around to shops that work on audi, they seem to do quite a bit on them as they showed so may be worth at least a phone call. good luck with who ever you decide on and your trip down the rabbit hole haha. Also when you get the engine back, break in is key, I still haven't got that far yet as my build has crawled to a stop being 2 hours away from the shop I use to work. once I get mine done I'm going to be breaking the engine in on my k04 setup until tax season. Then shooting for a single bw efr 9180. possibly fed by an eaton m90 but thats depends on the control system for the bypass I'm trying to design.
