Results 1 to 11 of 11
    May 05 2015
    How often to change coolant fluid?
    Just did my 70,000km scheduled maintenance and the service advisor is stating that the coolant fluid needs to be changed (for $180). How often should the coolant fluid be changed?
    Senior Member Three Rings focusaudi's Avatar
    May 02 2012
    Wrangler TJ, 2012 S4
    Denver, Colorado
    Apparently every time you go to the dealer.
    2012 S4 | ice silver metallic | DSG | prestige | AWE Exhaust | AWE S-FLO Intake | Alu Kreuz | eurocode sways and end links | 20% tint
    Apr 05 2016
    Portland, OR
    Checking the Scheduled Maintenance Intervals it is a check/add if necessary.
    Draining and refilling it is easy though, I just did it on my car when I put in the AWE Coldfront kit.
    You should refill it with G13 coolant: https://www.ecstuning.com/b-genuine-...ers/g013a8j1g/
    Geoff
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    I would wait till 100K miles (160K kms) to do that.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by Jiraffe View Post
    Old school is every 2 years.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Never. The container of Petrosin G12 ++ antifreeze that I have says "Lifetime Antifreeze" on the front.
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    In Germany no change ist needed. At the dealership it is just topped off if the level is low.
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Every 5 years
    May 05 2015
    Thanks for the replies. Any idea why they would recommend to change the coolant fluid now? Is there something I should be looking for?
    Jul 05 2015
    Lower Hudson Valley
    You know you can have the level of freeze protection tested.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    There's no such thing as "lifetime" fluid LOL
    Whenever I purchase a used car I replace all fluids.
    I replaced the coolant in the S4 when I did the cold front system. I probably won't do it again for several years.
    I've also done the rear diff fluid and transmission fluid even though it's claimed those are lifetime fluids...
