Results 1 to 6 of 6
    Senior Member Two Rings Bonz099's Avatar
    Jun 30 2015
    Rockville, MD
    Questions about RNS-E in a B6
    So im considering upgrading to an RNS-E in my B6, but im under the impression that the one from a B7 will not work without some wiring changes. Can anyone shed some light on this? I also have a Denison GW-Lite and would love to continue to use it, is that possible?
    Nov 17 2009
    You just need a plug and play harness. Took 10 minutes to install in my B6.
    996 TT
    MKIV Supra TT
    LX570
    Jun 30 2015
    Rockville, MD
    Quote Originally Posted by Ali View Post
    Link?
    Nov 17 2009
    996 TT
    MKIV Supra TT
    LX570
    Feb 04 2016
    London
    Rnse'e are getting on a bit now aren't they? You might be better off with something aftermarket and more modern.
    Sep 07 2011
    Indeed will work. I just put in an RNS-E from a B7 into my B6. You will have to buy the RNS-E adapter and antenna adapter though:
    http://www.euro-parts.us/store/index...tegory&path=59
    I do believe the Dension unit will work with it as well. Make sure to get the radio code for the RNS-E unit you pick up. I didn't and ended up using the eBay code retrieval method.
