My B6A4 is refusing to start and I haven’t the slightest idea where to begin. Here’s everything I know:
• Engine cranks just fine; just doesn’t fire until half a dozen or more attempts. The colder it gets the more I have to turn it over to get it to start. Could be the problem is worsening or it could be because the outside temperature has dropped below freezing. Example, this morning was 25 degrees; it took 26 attempts to get it to fire. If I let it sit overnight, I have to crank it several times. If I park it for a few hours, maybe once or twice.
• The engine idle speed is not normal. When it does finally start, it starts at the normal 800 or so RPM’s. It used to climb to 1200-1400 or whatever, then idle down to its normal idle. As a result, it stalls several times before it actually maintains idle speed.
• Once running, its 100% normal (no misfires). Jump on the gas and it pulls with no hesitation. I can drive it through town or on the highway and its fine.
• Mileage is the same as it always has been
• There’s no white smoke coming out behind me the car.
• I don’t own a VAG tool, but the car has no check engine lights on in the dash.
• Car has 188,000 miles on it. Still refusing to part with it.
As far as I have read, I should check the following:
• MAF sensor. Myabe disconnect it and see if it starts ok???
• Engine Speed sensor???
• IC hose. Not sure what this is???
Anything else I should check or test?
~ Before someone chimes in with the immobilizer... I swapped keys and it didn't help at all.
Appreciate everyone's advice.
