Hi,
I am running a 01E 6speed from a Euro A6 TDI in my A4 B6 and have noticed that there is quite alot of play in the driver side output flange ,about 1/8'' radial play in all directions. There also seems to be an oil leak from the same flange.
I noticed a vibration and ``clunking`` noise when bracking at high speeds with the transmission in gear. I am wondering if the faulty part could be the actual output flange shaft or the bearing or both ...
Any help on the specific part numbers and/or procedure to fixing this issue would be greatly appreciated since I cant seem to find an exact answer online.
Thanks !
