Results 1 to 3 of 3
    Jun 05 2010
    Slovakia, Europe
    Audi flat bottom steering wheel - No Longer Available
    New steering wheel for sale with S line batch, can be used in A6, A7, A8 models. If you have B8 model, buttons are switchable so it can be used in A4/A5 models. Also batch can be changed, it is possible to buy it at Audi dealership.
    List Date: 11/8/2016
    For more info, click here to view the original listing: Audi flat bottom steering wheel
    This item is no longer available.
    Senior Member Two Rings Laserrs's Avatar
    Oct 24 2014
    Cincinnati
    Been eyeing this, what's needed to do the swap?
    2014 A6 3.0t Prem Plus Ice Silver/Black 19" sport Vag Com
    Established Member Two Rings stingvb's Avatar
    Sep 13 2009
    2015 Jetta TDI on loan from VW
    Western Burbs of Chicago, IL
    Quote Originally Posted by Laserrs View Post
    If coming from a round wheel, you will need a new airbag as the round wheels won't work with the flat bottom. You can get them for around $700 from Alex at Europrice, but I had read that the OEM prices were going up from Audi. You will also need a #12 triple square to get the steering wheel bolt off. Plenty of youtube videos on how to do it. 15-30 minute swap and don't forget to disconnect your battery before removing your airbag.
    Edit: Just noticed that it looks like it does not have the shift paddles, so not sure if that is important to you or not.
    Good luck.
    2012 A7 Prestige - 20" Sport Package - APR Stage 2 - APR CPS - InJen Intake - P3 Boost Gauge - 034 Rear Sway Bar and End Links - AWE Touring Exhaust - S7 Flat Bottom Wheel
