Results 1 to 6 of 6
    Sep 05 2016
    PA
    Stage 1 misfire p0300 and p0303
    As the title states I am getting p0300 and p0303 misfire codes after upgrading to Eurodyne stage 1, I replaced my spark plugs about 1000 miles ago with denso PK20TT-INT, I have a spare coil pack laying around so I swapped that on cylinder 3 and helped a lot, but around 20psi the car starts to feel like it wants to misfire, shuddering and hesitation.
    Any suggestions? Should I try all new coil packs? Maybe a different heat range spark plug?
    Sep 05 2016
    PA
    It pulls pretty well with partial throttle, as soon as I step on it, the turbo tries to go full boost almost instantaneously. Is this normal for stage 1? It jumps to 22ish psi right away and stuffers...
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Try the High Pressure Fuel Sensor
    Located on the fuel rail (06J906051C, confirm fitment)
    and
    Low Pressure Fuel Sensor
    Located on the high pressure fuel pump (06E906051K, confirm fitment)
    That same thing happenned to me, plus i replaced the fuel filter too (4F0201511E)
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Sounds like you need a step colder plug if this issue still isn't fixed.
    Sent from my Pixel using Audizine mobile app
    2006 A4 6MT - JHM Stage 2 93 Oct flash | Cam Follower Conversion | JHM HFC | JHM Downpipe | B6 S4 Exhaust | JHM HPFP Internals | JHM Small Core FMIC | 034 RSB | Sway Bar Endlinks
    Sep 05 2016
    PA
    I went with a colder plug and all seems well. Thanks for the replies!
    May 03 2015
    North Carolina
    I did new coil packs and new spark plugs, as i had the same issue.
