Long story short....My car is a B8.5. I installed the Euro-code high-flow cat. Engine light came on. I got a 45 degree spacer. Engine light came back on after clearing it. I read that APR's tune disables the secondary O2 sensor. Wonderful I thought. I call GIAC and ask them if there's a way they can send my shop he programming to disable the O2 sensor and am told "we don't disable the secondary O2 sensor for legal reasons. They then tell me my flashloader can clear the engine light. So I check my spacer and O2 sensor to make sure it's not in too far into the cat. I follow Logan's instructions and guess what?.....the flashloader CANNOT turn off the CEL. I call GIAC back a few days later and Logan tells me that if I disconnect the positive and negative terminals on the battery and touch them together for 15 seconds, it will turn off the CEL. Guess what?....NOPE! Upon further investigation I learn that only a diagnostic tool like a vag-com can turn the light off. I'm so pissed that I pad $550 for a tune that won't even let me properly run a STG II without my check engine light constantly being on. I should have went with APR from the jump.
