Results 1 to 3 of 3
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    Adding Subwoofer and amp to B6
    So I'm ready to install those two this coming weekend with my buddy. Already have the Enfig plug and play kit installed.
    Will my remote wire connect to the Remote Output from my Enfig kit?
    Where is the grommet, or best grommet, at the firewall to run the power cable?
    //Auto Union Bay Area : NCAC Member : Motoza Stage 1
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    The amp out should work. But depending on what radio you have it may not have enough power. I recommend getting a relay. It doesn't have to be ours.
    http://enfigcarstereo.com/DEI_8616.html
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
    Jan 10 2013
    03 A4 Avant 1.8TQ
    We just T Tapped (I think that's what it's called) into the Remote wire works perfect.
    Also, in case anybody sees this thread in the future, for running the cable just remove the battery and pop the big grommet off and run your cable through it. Cut a hole in the actual grommet cover and run the cable through that and pop it back in place. Inside the car removing the glove box may or may not be need. I already had it removed bc trying to go through small grommet which was impossible
