Results 1 to 11 of 11
Thread: Alignment shops
    Established Member Two Rings merlinq21's Avatar
    Sep 03 2013
    2011 S4, 2015 VW Tiguan, 2012 Subaru WRX,
    Alignment shops
    Looking for a good alignment shop in Oakville or Burlington area?
    Any one have any suggestions
    Nov 13 2015
    Ottawa
    Also interested in a good shop to get my alignment done in the GTA area.
    Jul 28 2007
    RS5
    gta, ontario
    No one beats the dealer when it comes to the perfect alignment.. they have high dollar machines that do a great job. Hamilton Audi is less busy than Oakville.
    Mar 06 2008
    17 Allrroad, KTM 530 and K1300r
    Rhill
    Independent Tuning in Scarb.
    2017 SQ5 Silver Teknic
    2017 Allroad Silver
    2008 A4 Avante 6 spd SOLD
    2009 STI Hatch SOLD
    Sep 03 2013
    Thanks Miss audi did my car and I have one tire that is fried - all other tires look fine- they did the alignment and it looked good on paper. The last service they said tires were in good shape - put the winters on and the pass side front if pooched.
    may try hamilton Audi as they are closer to home
    - - - Updated - - -
    Thank you
    Jun 19 2014
    Thornhill
    Correct me if I'm wrong, but based on my research many Audis require you to recalibrate the steering angle sensor once the alignment adjustments are completed. That's why the dealerships and high end shops charge more.
    Jan 06 2009
    It literally takes 30 seconds to recalibrate the G85 steering angle sensor using VCDS.
    For alignments, there is a big difference between setting everything within the spec values and setting it correctly. For tire longevity and optimal tracking, you want as close to zero toe as possible on the front (both sides) with just a very slight ammount of toe in (only a few arc mins toe in). You also want matching values left/right assuming your subframes are centered. (The dealer will likely be the only place that will be able to properly center the subframes in addition to the suspension adjustments).
    If you are lowered, or even factory sport springs it is important to have the bump steer set appropriately (height of outer tie rod relative to steering knuckle). Again, the dealer would be best for this.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Three Rings jcs's Avatar
    Jul 22 2009
    GTA, ON
    Look up can-alignment in Flamborough. Scott is the only person I get alignments done from.
    2009 A4 2.0T - APR Stg II+ + Eurocode HFIC + Eurocode HFC (Uninstalled) + Eurocode Twin Tip Catback (Sold) + Gloss Black Front Grille + Custom Gloss Black Fog Grilles + RS6 Pedals + RS5 Dead Pedal + RS6 Shift Knob + Gloss Black Vinyl'd Front Splitter + Gloss Black Vinyl'd Roof + 35% Tint + DavidB8 Tail Light Mod + LED License Plate & Interior Bulbs
    Sep 03 2013
    Quote Originally Posted by jcs View Post
    Thanks
    Feb 15 2016
    Cambridge,Ontario
    if only one tire was pooched id be checking for worn / damaged suspension components before I would be getting an alignment done.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Sep 03 2013
    Audi said all looked good, however, my trust of them is waning. I am looking for a shop to check it out- may try Hamilton Audi next.
