Results 1 to 40 of 40
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    C7.5 APR Stage 1 100oct : [email protected]
    I've been testing APRs Ecu/Tcu tune, finally found time to go down to the track. Making a thread to post my results.
    Car 4405 & "BLACK"
    DA: -766
    First time slip stamped 7:44PM
    This is the first run of the night with ms100 on 93 map.
    Used 5.5k launch by just holding the gas down and letting off the brake, resulted in little wheelspin but shifted harsh into 2nd. Car otherwise ran strong down the line.
    Second time slip stamped 8:03PM
    Second run of the night, still on 93 map to let ecu adjust to the ms100.
    With this I used sort of a launch method in my 6mt, I can't let off the brake obviously like a clutch, so I just dumped it. On the upsweep I would let off at 3.5k-4K, hooks up quick without over powering the launch. 1-2 shift was butter smooth and so was every other shift throughout the run.
    Eyes opened when I looked at the slip.
    Third time slip stamped 10:08
    Car is labeled BLACK for some reason, guess they didn't get my number. I kept opening my windows With the heater blasting, numbers started to fade.
    This is my best time after about 3 more runs on 100 map, just couldn't hook up at all no matter what I did.
    I wasn't going to play with air pressure since I have nitrogen and no air compressor anyway. Trap was awesome otherwise.
    Looking at this slip, it seems like 100oct file would be good for 11.1xx if I can get it to stick; or if anybody can get it to stick at that.
    Sorry for any mistakes, I'm on the run right now lol
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Nice runs, would live to see how it does on just 93 oct
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    Is that a record 4.0T stage 1?
    Feb 09 2016
    Houston
    Quote Originally Posted by saxon View Post
    Do you think it would have differed? He ran the 93 map with race gas in the tank. Surely all knock would have been eliminated with 93 in the tank in that air. But race gas is sometimes oxygenated and that might help things.
    2014 A8L 4.0T - RS7 Turbos, DS1 Stage 3 Tune, Full E85, Stock Downpipes, Stock LPFP. [email protected] mph
    Feb 09 2016
    Houston
    DGVR6, the 11.2@121 run is fantastic for the 93 map regardless of what was in your tank. Excellent! At what track did you run?
    Aug 03 2014
    Queens
    Thanks Saxon, I really can't wait to see how Uni does on stage 2. With the stage 1 speed you're trapping on 93, it sure was on its way for 11.4xx with the right 60 and 330.
    I'll definitely get some 93 runs in soon.
    Quote Originally Posted by ntsantos View Post
    Yes
    Previous
    Aug 03 2014
    Queens
    Quote Originally Posted by Chris Morales View Post
    Thanks Chris, these runs were at Atco raceway.
    Previous
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by DGVR6 View Post
    Sounds like what the B8 guys recommend for the best launch control method. Good runs OP.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    Impressive!
    I dont think traction was an issue for you. Low 1.60s for the 60ft is damn impressive, almost drag radial times! I could only wish for such 60fts!
    2015 Porsche 911 Turbo S
    Feb 25 2014
    Texas
    Almost, but not entirely irrelevant since he was still running the 93 map.
    As Chris stated, I would imagine 93 pump would have been plenty sufficient given the temps of the evening on the 93 file. If it were 80+ degrees with a higher DA, your argument may make more sense.
    Great ET/trap OP!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Oct 16 2012
    pa
    Quote Originally Posted by AudiS4B8 View Post
    Great ET/trap OP!
    its very hard to say who's right and whose wrong. I dont think there is enough data out there for anyone to know the answers except the companies tuning these cars. a 2mph gain with the switch doesn't seem like a big difference but i guess from apr's figures they only show a 20whp gain with race gas.
    i know on my apr tuned s4 i would pick up power and trap speed by going with race gas even in the colder temps, but i also logged the car and saw that timing was higher due to the race gas compared to what it would achieve with pump gas.
    i'm obviously not trying to discredit his times as they are awesome! i wish i could get the same traction that he says its lacking lol!
    Feb 25 2014
    Texas
    100% agreed. We would need to see logs.
    10.65 @ 129mph
    Aug 03 2014
    Queens
    I'd have to say regarding race gas on the 93 map, Saxon is most likely correct. How much timing advanced on the 93 map, I have no clue.. I forgot my cable.
    Seems to me around a 1-1.5 mph gain over 93 with the essentially 97.5-98.0 octane mix I was running that night. I'm sure the 93 calibrations were maxed out.
    Traction was not an issue until I switched maps over and the temps started to plummet. I was pretty lucky to get there before that
    Previous
    Sep 19 2014
    Newcastle
    What does the nitro in your tyres do? I know the gtrs run that set up
    Would that help traction?
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Aug 03 2014
    Queens
    Quote Originally Posted by pez81 View Post
    Nitro just pretty much helps with keeping pressure stable within the tires. It's less prone to air pressure fluncuation caused by ambient temperatures or heating/cooling of the tires. Also doesn't lose pressure as much as air throughout the months
    Could very well help if your tires heat up after every run and want it to stay around a consistent pressure
    Previous
    Oct 16 2012
    pa
    nitrogen is essentially an upsell (in my industry) as it doesn't change as much in temperatures and keeps the tires at a consistent pressure and typically you don't lose tire pressure in the winter time like normal air.
    Feb 25 2014
    Texas
    That would mean APRs 93 tune is pretty aggressive
    10.65 @ 129mph
    Aug 03 2014
    Queens
    Yep.. I'd still have to log timing, ign knock, fuel trims
    Previous
    Sep 19 2014
    Newcastle
    Ah thanks for that. I don't think many places supply it near me anyway.
    Oct 16 2012
    pa
    they typically "request" higher ignition timing than necessary as the computer will compensate depending on the conditions. technology is great!
    Feb 09 2016
    Houston
    Well at the least it doesn't seem that APR's current stage 1 tune is lacking anything performance-wise compared to Unitronic's.
    Aug 03 2014
    Queens
    Right, the trap on my signature with the b8 s4 is a good example as that was a 93 map maxed out.
    Unitronic didn't have a 100/104 map for the s4 though but did advance timing quite a bit on the "aggressive" 93. I would not see that on pump.
    Definitely not, APR is producing some fast cars. I do like the tune, I'm sure I would've been trapping 124 if I completely ran straight 100.
    Previous
    Jan 09 2013
    UK
    Revolution will do Nitrogen fill for you, heading over there tomorrow to have some 'bits' done to the '7 and will probably ask them to do a Hunter laser alignment check and Nitrogen inflation at the same time
    Sep 19 2014
    Newcastle
    Quote Originally Posted by P_G View Post
    Do they? I'm due some new tyres so will go there and get the hunter alignment at the same time. I removed the front resonators today mate, miles better.
    Feb 09 2016
    Houston
    Regular air is 78% nitrogen already. I found this article informative as to why pressuring with "pure" nitrogen is a waste of money: http://www.edmunds.com/car-care/shou...-nitrogen.html
    Jan 09 2013
    UK
    They'll be pretty close to the best price you can get if not the best for tyres when you include fitting, balancing, Nitrogen and disposal.
    Nice that you're happy with the resonator delete, gets better after a few runs out and the bedding in period is done.
    Jan 09 2013
    UK
    If you want consistency in pressures on low profile performance tyres it is from experience worthwhile because Nitrogen molecules do not permeate as readily as Oxygen etc. or put it another way the 22% including water vapour that will permeate through the tyres. For standard tyres on a Ford Focus for example I'd concur it's not worth the money. However if you also get it for nothing or a few £/$ then why not?
    Senior Member Three Rings Carl Weathers's Avatar
    Dec 20 2014
    Chicago
    ATCO is home to many a record run. Fast track for sure.
    2012 Audi A6 3.0T Fully loaded sans B&O/Nightvision, 20" Rohana RF2 wrapped in Ventus V12, APR Stage 2, AWE exhaust
    2005 Pontiac GTO, Procharged with D1SC 553/550 at rear wheels on 7lbs of boost
    Feb 25 2014
    Texas
    Right. APR in the past was not known for putting out the most aggressive maps so it's nice seeing these posts. I definitely am shopping multiple different tunes now.
    10.65 @ 129mph
    Sep 19 2014
    Newcastle
    Much happier now. I like revolution good guys
    Feb 09 2016
    Houston
    Quote Originally Posted by Carl Weathers View Post
    So true. Not to discredit the times in this thread, but chances are if you're talking about a national record on any platform it was done at Atco (or maybe MIR) this time of year. I would love to run there one day. Just a 1600 mile trip for me.
    Aug 03 2014
    Queens
    There a black hole at the end of the strip at this time of year
    Previous
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Nice work!
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Sep 04 2011
    Central NJ
    Trying to understand how you launched. I assume for the first run you used launch control with 100% throttle and kick-down switch engaged at 5.5k rpm and for the second run you did the same but took your foot off the brake before the engine reached 5.5k rpm (i.e. at 3.5k-4k rpm). Since you have the APR TCU tune did you try to launch at lower rpms by just giving 50% throttle or 100% throttle without kick-down switch? That should give you 3.5k or 4.5k rpm if I guessed your launch profile correctly.
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Aug 03 2014
    Queens
    Quote Originally Posted by Arin@APR View Post
    Nice work!
    Thanks Arin
    Quote Originally Posted by hmuller View Post
    Yep, first run was foot flat on the gas with the kick down engaged, 5.5k launch.
    2nd run was exactly how you described.
    I'm still playing around with launch control so I haven't successfully used the lower launch limits yet.
    Previous
    Aug 03 2014
    Queens
    Went to the track last night, didn't get many runs in, someone blew their motor out on the track.
    Was testing the launch control settings in APRs TCU tune running on shell 93.
    -1000 DA.
    Car 4406
    3.5k launch
    Personally, I feel the upsweep method still works best.
    Previous
    Oct 16 2012
    pa
    That time is still very impressive for stage 1
    It seems 1.6 sixties are the key to low 11's
    Feb 14 2014
    13 S6, 13 Q5, 72 Chevelle
    Oklahoma City
    Killer. Backed up your others pretty much. Maybe the 100 octane on the 93 map does give you a little something. If you would have pulled a 1.65 60' would been right back at 11.3
    Is that neg 1000 DA, or just a dash?
    Super jealous of those weather conditions
    Oct 16 2012
    pa
    I know with my unitronic tune I was pulling nearly 5* of timing with a "bad" batch of Sunoco 93 octane. I went back to my normal shell 93 and no timing pull. Still ran 11.6@120 with 5* of timing pull and not using launch control :)
    Aug 03 2014
    Queens
    Landing good 60 will get you into the low 11s without a doubt.
    Yea DA was at negative , I always take advantage of novembers weather up here lol
    Previous
