Results 1 to 8 of 8
    Jul 15 2015
    Rochester NY
    Service position bolts?
    Hi, searched high and low on the forum and nemiga but couldn't find information on the long service position bolts. Could someone give me a part # or just describe the bolts - I think they have a sleeve as well? I searched on jhm and ecs for "service position" but nothing came up.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Check on ECS, I bought mine for ~$10
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Senior Member Three Rings REVOofRustler's Avatar
    Jan 18 2014
    Redmond, WA
    2004 S4 Avant 6MT Dolphin Grey
    | JHM Tune | JHM Short Throw Shifter Trio Package | Fast Intentions Dual 2.5 Resonated Catback | JHM 4:1 Center Diff | BC BR Type Coilovers | Hotchkiss Rear Sway Bar
    Instagram: tha_notorious_b | rotational.media
    Established Member Two Rings Ryanroland's Avatar
    Mar 11 2015
    Honda S2000
    California
    I ordered mine last week
    2006 S4 Brilliant Black | Europaparts cat back exhaust | H&R Springs | B8 S4 19" Peelers | I really need more mods to make this look cool
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    You don't need those bolts on a B7 or older car. Just let the core support hang on the low speed impact shocks since they go in the frame rail a bit.
    The B8 and newer cars need those bolts because they are different and nothing is there to support the core support.
    Jul 15 2015
    Rochester NY
    Thanks REVO, yes, danged if I could find them - thanks for that. Jimmy, good to know - much appreciated! I've done just about everything I want to the engine and transmission so am getting close to putting it all back in the car (after 12 months, I've still managed to find all the parts. I can see a brake lathing in my future though - they'll be really crunchy by now...)
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Pull one if the bolts and head to the hardware store and get them in the desired length....I keep a pair in the tool box...
    - - - Updated - - -
    *of
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    M90x1.25 bolt.
    Put a fender washer on it.
    Get some small diameter iron pipe, and slide over the bolts. The pipe is 1/2"x2" black steel nipple, with the threads cut off on one end: http://www.homedepot.com/p/Mueller-G...20HN/100197895
    Here's what I put together at Home Depot
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
