Results 1 to 21 of 21
    Established Member Two Rings Stinky s4's Avatar
    Sep 15 2016
    Nyc,Washington heights
    Rear lower control arm removal helpppp
    Am trying to remove the rear control arms but the e brake cable is the last thing I need to remove...where do I remove the cables from do I have to take off the wholeee cable from the interior or is there somewhere else where it's easier?? Am in the shop as am posting
    Feb 19 2016
    B5 S4 Avant e60 m5
    Bethlehem pa
    Can you remove it from the rear caliper and pull it through that way
    Sep 15 2016
    Nope
    Established Member Two Rings shepa401's Avatar
    Oct 20 2011
    Wisconsin
    I pulled mine by carefully taking a dremel to the plastic collar.
    Dec 10 2013
    Borden, Ontario, Canada
    Straight from my build thread.
    Quote Originally Posted by Bordom View Post
    Little update here. No mods in yet because maintenance is crucial.
    Started stripping some of the components to get the rear subframe out of the noggy.
    There's a plastic clip here that keeps the parking brake in place. After 20 minutes of fiddling trying to get behind it, I decided to pry it off. Popped right off with some force.
    To get it off the line, you cut it off. I won't be replacing this as I don't feel it necessary
    Pass the parking brake cable through the hole
    Then here you pass it through the secondary bracket
    And it's free! You will have to break/cut this plastic piece at the rear of the arm as you won't be able pass it through the second bracket.
    The plan is to daily the S4 before November then I can throw on my B7 RS4 rep winters and get proper summer tires later on
    Everything graciously mispelled by Android
    Sent from my SM-G935W8 using Tapatalk
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Sep 15 2016
    So wait you just simply broke the plastic ?
    Dec 10 2013
    Quote Originally Posted by Stinky s4 View Post
    Yes, break the clip, then break off a section of the parking brake cable to be able to slide it through the last hole. There's no other way to do it that I know of.
    I've successfully run my car like that for over 1 yr and 30k+ km with the cables reattached without the clip. No issues there
    IG: 24_et
    Sold:
    RIP:
    Oct 20 2011
    Wisconsin
    This is how my cable looks after I took the control arm off.
    Sep 15 2016
    Thank you guys I just ended up putting the arm back together but next week I will take off both control arms... What you guys think of energy suspension bushings I got some black series would they be good for daily driving idc about the stiffness I want to know how good is the life of the bushings
    Dec 10 2013
    Poly bushings? They'll start to squeak and you'll hate your life.
    OEM Loemfoerder bushings aren't that expensive.
    IG: 24_et
    Sold:
    RIP:
    Oct 20 2011
    Wisconsin
    I just bought the whole control arm bushing kit from BLAUParts.
    http://www.blauparts.com/proddetail.asp?prod=MA21014-C
    Dec 10 2013
    I'd like to know makes this kit. I don't buy things from BLAUPARTS because it looks cheap. Let us know how long these last you
    IG: 24_et
    Sold:
    RIP:
    Feb 27 2011
    Winnipeg
    most likely Meyle or a mix of Meyle, Lemforder and Febi. The upper rear control arm bushings as far as I know Meyle is the only one who makes them. Rockauto was wholesaler clearing a whole bunch a while back and I bought all of the remaining stock for $1.50 each. With the low demand for these parts I don't think there are any chinese garbage copies floating around anywhere which is why they're so expensive.
    Dec 10 2013
    Quote Originally Posted by seanf86 View Post
    I need 4 rear upper inner bushings. Wanna ship me those at $2 a pop plus shipping? Lol
    IG: 24_et
    Sold:
    RIP:
    Sep 15 2016
    Lol @ bordem I think they won't squeak if you coat them the insides with copper lubricant
    Dec 10 2013
    Yeah, short term. Eventually you have to take it apart again to lube it up. I'd think it's a 6month-1 yr service interval at least
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    I did the same when i swapped frames, over 2 years its no issue
    Sep 15 2016
    I wouldn't mind to be honest is going to be a grip monster though
    Oct 20 2011
    Wisconsin
    Out of curiosity I contacted BLAUPARTS to find out who the manufacturer is on their kit and it is MEYLE.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    as far as poly bushings, you're just tinkering. Yes they replace the bushing with full ball-bearings for race cars, but it's just a bit of deflection in the system -- it's not the biggest deal. The hastle with replacements and noise is very rarely worth it. As far as it drastically improving grip, hardly.
    I've rocked poly bushings (and race rod ends), yeah they start squeeking after a while... personally I DGAF about squeeks/rattles. But I just didn't notice any real tangible difference. A long as the bushes are in decent condition you're good. My problem is they're a pita to install and they just don't really do much.
    Sep 15 2016
    Thanks bro I think am just going to drive it like that
