I posted in one of the rear sway bar threads about this same noise and had found out I'd stripped the hole in the lower control arm. I ended up having the control arm replaced rather than try to re-thread to the next bigger size. I moved the sway bar to the inner hole after reading a couple of posts. The problem is I'm still hearing the noise. It doesn't happen at highway speeds but if I'm driving 50 mph or below and I hit a bump or uneven stretch of pavement I hear the clunk/rattle sound coming from what seems like the rear axle area. I've checked to make sure the end links and bolts aren't loose and I reconnected the bolts for mufflers so I'm at a loss for what it could be. Anybody have any ideas what it could be?
