Results 1 to 9 of 9
    Senior Member Three Rings stevemiller333's Avatar
    Oct 22 2016
    05 B6 S4 SDN, E46 M3 VERT, 2018 F150
    Rochester, NY
    Chain rattle after oil change.
    I just got my new car and changed the oil for the first time. Used moly, ordered the kit from ECS. When I started it after the oil change I heard a very loud chain rattle. I have heard the occasional cold rattle on this car but this sounded a lot worse and was for about 2 seconds rather than less than 1 second. i understand the principles involved here with the tensioners so I am curious, did I miss a step that could have prevented this? Should I have pulled a fuse to prime the tensioners?
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    First start after a change is always a bit rough for me as well, especially if the car drains for a while.
    My $0.02: Not sure what you could do to really prime the system; even pulling the fuel pump fuse or something you still need engine turnover to pressurize the oil, which will rotate the chains - whether fuel is being combusted or not doesn't really matter (when focusing on chain tensioners at least).
    Also, congrats on the new ride and welcome!
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Oct 22 2016
    Rochester, NY
    Thank you sir! I love this car.
    Oct 03 2015
    West Hartford, CT
    Quote Originally Posted by stevemiller333 View Post
    just changed my oil yesterday. first startup post sounded it a bit different than before the change.
    not saying good or bad just sharing to say your experience not alone
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    May 28 2013
    Australia
    It will always do this due to the need to fill the oil filter housing and other parts of the oil gallery prior to getting good pressure to tensioners etc. Personally I hate this, so I pull the fuel pump fuse prior to the last shutdown to remove the fuel pressure, then after the oil change, crank to prime, then install the fuse to start. Sounds beautiful. I've been doing this for years on all of my cars
    Oct 22 2016
    Rochester, NY
    Quote Originally Posted by jjrichar View Post
    Thanks. That's the kind of trick I was looking for! I will do that next time. Yesterday I had my first cold morning start with the car. Prior to starting I turned the key so the starter just started to crank and then let off. Probably turning the crank shaft 1/4 to half turn. I did this three times then fired it up. No cold start rattle!
    Jul 15 2015
    Rochester NY
    Some folks install pre-lube pumps to get the oil up there in advance of starting. I think running a line from the fuel pump fuse block to a switch on the dash would be a simple alternative but it seems easier to just pull the fuse on the occasional oil change
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Oct 22 2016
    Rochester, NY
    Quote Originally Posted by Terry.Reese View Post
    Interesting. Yea I did my crank start technique about 1/2 hour ago on a cold start. Made a totally different chain noise. It was a little delayed. I guess that's how this car is gonna be! I think I will stop cranking it without starting it, probably bad for it anyways.
