Results 1 to 4 of 4
    Junior Member Two Rings ReevesL's Avatar
    Nov 06 2016
    A4 B6
    Bellevue, WA
    Oil on spark plug, thoughts?
    Hi Audizine,
    I'm in the process of pulling the 2.7T from my A6 to put into my A4. As part of the prep work I pulled the coil packs and did a compression test.
    When I pulled the #3 coil I noticed oil on the spark plug end. When the spark plug came out it also had oil on the top, but the business end still looked clean. All other coils were dry. The compression test showed 160's on 5 of the cylinders and 200 on #3.
    Any thoughts?
    I'll have the engine out and on a stand before it goes in the B6 so I have a chance to tear into it, I'm just hoping I don't have to do a full rebuild yet (hoping to leave that for a future project ).
    My stable: Q5 3.0T (daily driver), A4 B6 1.8T Avant (2.7t swap project)
    Train Wreck build info
    Established Member Two Rings SimbadCA's Avatar
    May 11 2016
    Audi TT (MK1, 8N) Quattro
    Camarillo CA
    Quote Originally Posted by ReevesL View Post
    Hi Audizine,
    Any thoughts?
    Is the valve cover leaking near that cool assembly? Perhaps the oil got past the coil seal?
    I'm not that familiar with the 2.7.
    Sent from my iPhone using Tapatalk Pro
    Nov 06 2016
    A4 B6
    Bellevue, WA
    Thanks for the suggestion SimbadCA. I'll be pulling the engine this weekend and will get a closer look.
    May 11 2016
    Camarillo CA
    Did you find the source of the problem?
