Originally Posted by
DC242
Hi all, I just purchased an '08 A4 Avant with a Symphony II+ stereo. I have an old Ipod touch 4g I want to just leave in the glove box for music which is what I did in my old B6 A4 using a Dension unit. But I have a couple questions about this in my B7.
1) What I would ultimately like is a setup that would allow for text/song info on the head unit itself. From my research, it doesn't appear that anyone makes something that is capable of this although it seems possible if the sat radio line was used. Does anyone know of a solution to accomplish this?
2) The car has the OE ipod dock in the glove box. If there is no way that will allow me to get text on the head unit, I would like to use the OE ipod dock since it's there and I don't care about text on the cluster MFD as I find it distracting. However when I plug my ipod in, the radio seems to recognize it and will control it (switch songs, etc) but I get no sound. Any ideas why this might be? The Ipod wont charge because of the voltage issue (12v vs 5v); is this the reason I'm also getting no sound? The car does have SAT radio, but no receiver hooked up.
I've done a lot of searching on these two issues, and have found nothing so thought I'd post. Thanks for all the help and suggestions!
Dice used to make an interface that used the sat port but it worked so poorly that we had to stop selling it at least 5 years ago. I've never understood why people prefer the text on the radio instead of in front of their face but that's why the word opinion exists.
There are different versions of docks and many reasons why they don't work. The IPDU is the most popular replacement for a factory iPod dock.
Here are your options. Unless specified they replace your ipod adapter in the glove box.
First the keys to remove the radio and/or CD changer
http://enfigcarstereo.com/ENFIG_RRK4...OOLS_KEYS.html
1. Simple AUX
http://enfigcarstereo.com/ENFIG_AUT_AUX.html
2. AUX + 30 Pin ipod with song+/- and playlist+/- controls from radio and steering wheel controls. (no text)
http://enfigcarstereo.com/DENSION_GW1LAUT.html iPod + AUX
3. AUX + USB for iPod iPhone with song+/- and playlist+/- controls from radio and steering wheel controls. (no text) (USB will charge android from USB but no control and audio from aux)
http://enfigcarstereo.com/ENFIG_AUT_IPDU_AUX.html iPod via USB + AUX
4. AUX + 30 Pin ipod with text on cluster and full ipod browsing through steering wheel controls.
http://enfigcarstereo.com/DENSION_GW17AC1.html iPod + Aux with song info in the cluster.
You can swap the 30 pin ipod cable for the unit below to have a female usb for newer ipod's iphone's that use the lightning cable.
http://enfigcarstereo.com/DENSION_LIA1GW0.html
Must be connected behind the radio so if you are using SiriusXM satillite radio you must get the part below. If you are not listening to satellite radio then the part is not needed.
http://enfigcarstereo.com/ENFIG_AUDI_SAT_PASS_3.html
5. Wireless bluetooth for calls and audio no text. song +/- through bluetooth.
http://enfigcarstereo.com/DENSION_GBL3AI2.html USB + Bluetooth with option for iPod and aux
You can add a 30 pin ipod cable to get charging and a little better audio.
http://enfigcarstereo.com/DENSION_IPO5DC9_NC.html
You can add the unit below to have a female usb for newer ipod's iphone's that use the lightning cable.
You can add an aux to this unit.
http://enfigcarstereo.com/DENSION_CABL_AUX.html
6. Bluetooth with text, USB for ipod and memory sticks AUX with adapter below. full browsing of ipod on cluster.
http://enfigcarstereo.com/DENSION_GWP1AC1.html USB + Bluetooth aux with option for iPod that shows text.
It is strongly recommended that you get the item below with the item above becasue it has a reset button for the few times a year it needs to be rebooted (like a computer)
http://enfigcarstereo.com/DENSION_EXT1CP2.html
