Results 1 to 3 of 3
    Established Member Two Rings bmartin247's Avatar
    Nov 17 2015
    Denver, Co
    Oxygen sensor interchangeability
    Can 3.0 o2 sensors be replaced with 2.8 o2 sensors and vise-versa?
    Sent from my HTC One M9 using Tapatalk
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Check the Bosch part numbers to see if they match
    Sent from my Pixel XL
    Dec 05 2007
    Not always about part numbers. It has more to do with specs. If they match up, they can be interchanged. Differences between part numbers can be something as simple as a difference as cable length or connector design. The electronic specs is what will dictate if it will function or not if used on a different application. But if part numbers match, your search for the true answer was made more simple.
